Question about Lexmark E Office Equipment & Supplies
How do I change the HV power supply on Lexmark T642
Need to change the HV power supply does any know the order in which to get to it ?
All Office
  • 58 Answers
SOURCE: Wiper blade
When you say wiper blade, do you mean the one in the cartridge? There's also a cleaning wand in the top of the fuser.
Posted on Jan 22, 2008
Crankstart
  • 696 Answers
SOURCE: T642 Laser Pinter
This is a call for service message generally requiring professional repair.
There are generally only four reasons:
No power, Check fan power leads as one may have slipped off it's fitting
Jammed: Either too dirty or a shred of paper may be blocking the blades, pull free and clean off with compressed gas(no more than 25ft/lbs)
Dead fan: Call a repair man or call lexmark and give them the exact code,they will identify the fan and can sell you the part.
Dead controller board: as with above call a repair man or lexmark with code and order spare part.
The only bad news other than you may need a repairman, if you order the fan or controller board it may be the other and no way to know ahead in some cases.
The good news, if you're still under warranty, lexmark has good repairmen and fast response times in most areas.
Either way, Hope this helps FixYa,
Chris
Posted on May 10, 2009
  • 320 Answers
SOURCE: Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Posted on Nov 28, 2009
SOURCE: power on reset T642
Failsafe way. . .pull the plug out, wait ten seconds, plug it back in :-)
Posted on Dec 10, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: where to change the setting of a lexmark t642
    The setting should be on the driver. Once you are ready to print a document just select print then printer options and you should see the option of two sided printing and select the long edge or short edge. If you want to know where in the printer menus is the option, then go to the printer menus then select Finishing Menu then Duplex and just select ON. that should activate the duplex option.
    Posted on Feb 09, 2010
    What can i do when my lexmark T642 printer displays 922.02 service fuser error when the printer was never used?
    It could be the connector to the fuser from the LVPS is not connected properly. It could also be the Thermistor on the fuser is bad.
    Jan 31, 2017 | Lexmark T642 Laser Printer
    How do I change toner to my Lexmark T642. I can't find an instruction in the manual. The instruction in the toner cartridge is ununderstandable. I can't find what to press to remove the old cartridge....
    Good day! Error 1203 means that there is a communication failure between one of the cartridges and the pritner. Try these procedures to help you resolve the problem:
    1. Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. If no go,
    2. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on. If the error pops up, there is a hardware problem with the printer.
    3. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. If the error still pops up, continue cleaning or replace the cartridge. If no error,
    4. Do step #3 again for the black cartridge. If error pops up, continue cleaning or replace black cartridge. If no error, print a test page.
    Hope this helps.
    Mar 20, 2010 | Lexmark T642 Laser Printer
    Power on reset T642
    Dec 10, 2009 | Lexmark T642 Laser Printer
    Nov 23, 2009 | Lexmark T642 Laser Printer
    T642 Laser Pinter
    Chris
    May 10, 2009 | Lexmark T642 Laser Printer
    We can't get the lexmark t642 printer to work at home
    The printer is not hooked up to the wireless network. It will work if hooked up with an ethernet (hard wire) cable. Anyway, it is a royal PIA to set up - let him take care of it.
    Sep 01, 2017 | Lexmark T642 Laser Printer
    Realign the print on my Lexmark T642 printer
    You can adjust the print registration settings in the Config Mode of the printer. I believe you hold down both the down arrorw and right arrow button when you power on the printer
    Jan 12, 2009 | Lexmark T642 Laser Printer
    SE Menu for Lexmark T640
    Its a two key combo. Try the following;
    Press and Right arrow and menu together and power on printer OR
    Press and Right arrow and GO together and power on printer
    Jul 31, 2008 | Lexmark T642 Laser Printer
    Lexmark T642 Missing Character
    change font size CPI from 10 to 15
    Jul 04, 2008 | Lexmark T642 Laser Printer
    Lexmark T642: Will not print text files in Linux
    You need to download the Postscript drivers from Lexmark site.
    Oct 28, 2007 | Lexmark T642 Laser Printer
    18 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
