Question about Dell P1911 Monitor
How to unlock monitor OSD on p1911? - Dell P1911 Monitor
  • 70 Answers
Hold down the bottom 2 buttons for 15 seconds.
Posted on May 07, 2014
How do i fix osd lock out on an hp monitor
Follow this link: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Basically you have Four options.
Fix One:Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Good luck and thanks for using FixYa.
Mar 05, 2011 | HP w1907 LCD Monitor
What does osd lockout mean and how do i get the box off my computer
Lockouts occur when the software driving the OSD encounters a problem or conflict--akin to your PC's operating system freezing.
Follow this link for more info: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Basically you have Four options to solve an OSD lockout.
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Fix Three:
Fix Four:
Feb 22, 2011 | HP w1907 LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Osd locked message from HP in on for the first time. What is osd and how do I get rid of it?
When the OSD is locked, settings cannot be changed in the OSD menu. To Unlock the OSD, press and hold the MENU button on monitor while the monitor is off, then press the Power button to turn the monitor on. To lock the OSD, repeat the Unlocking procedure.
Mar 17, 2010 | HP W19b LCD Monitor
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
I have got a problem with my 17 inch viewsonic monitor. as i open the monitor it shows osd locked. pls get me the solution.
Assuming this is a E70fB monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
Userguide available at http://www.viewsonic.com/assets/027/7929.pdf
Mar 02, 2009 | ViewSonic E70f 17" CRT Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
Dell P1911 Monitor Logo
114 people viewed this question
Alun Cox
