Question about Vacuums
Power button dyson dc44 - Vacuums
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Dyson.com or punt?
Posted on May 06, 2014
My Dyson DC44 Animal is not charging.
Here is how i fixed my Dyson dc44 not charging, it turned out to be easy, but i went through checking everything else on the way to find a simple fault and fix
Apr 10, 2017 | Dyson DC44 Animal Cordless Vacuum
My Dyson DC44 animal has the MAX light on all of the time but it appears empty....any ideas?
ring dyson for support it could be the micro particle filter is blocked up and needs cleaning.
Dyson have really good support
http://www.dyson.com.au/support/dc44/dc44-animal-bu/maintaining-your-dyson-machine/wash-the-filters
Sep 10, 2016 | Dyson DC44 Animal Cordless Vacuum
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
Green light comes on when I try to use it
Hi there, it's Jack at Dyson.
If your DC44 won't run when you hold the trigger down, but displays a solid green light, this indicates that the battery is out of power. If this continues after you've connected the machine to the charger cord for at least 5.5 hours to recharge fully, it suggests that there could be a fault with the charger, battery or main body.
When you have your DC44 to hand I would encourage to you call the Dyson Customer Helpline so our experts can talk you through some simple diagnostic checks. Once we're clear which part is affected, we can confirm if a replacement is covered under your Dyson warranty.
You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Jul 23, 2015 | Dyson DC44 Animal Cordless Vacuum
Should a Dyson 45 battery work on a Dyson 44 motor head?
The listings on 3rd party batteries like at NewEgg (
HQRP Battery for Dyson DC31 DC34 DC35 DC44 DC45 DC56 Series plus HQRP... ), Ebay (
NEW DYSON DC44 DC45 VACUUM Battery Type 2000Mah CORDLESS DC34 DC35 4402B ), and others lump the battery for the DC44 and DC45 together, so you're probably fine.
You may want to take the battery to a Batteries Plus or such - sometimes a battery will show voltage just fine, but choke once there's a load on it. They have the gear to tell (same as with car batteries)
Good Luck
Apr 11, 2015 | Dyson Vacuums
Can you wash clear bowl on a dyson dc44
We would strongly advise against attempting to wash or submerge your DC44's clear bin, as it contains the wiring which supplies current to your vacuum's wand and motorised floor tool. Any damage caused may not be covered under your Dyson warranty.
Instead, we'd recommend separating the clear bin from the cyclone pack as shown in the image below:
Once you've removed the clear bin, you can use a damp cloth to remove any dust or debris - always make sure the bin is completely dry before reassembling. You can also use a soft, dry brush to remove any debris from the shroud.
I hope this helps, but if you'd like any further guidance on cleaning or maintaining your DC44, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 28, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
Why won't my Dyson DC44 rechargeable vacuum brush attachment not work or pick up anything?
Hi Kim, it's Jack at Dyson.
If your DC44's motorised cleaner head doesn't seem to be picking up as well as it should be, it sounds as if there is a blockage somewhere. To check for this, please follow the steps shown in our Support guide: http://www.dyson.co.uk/support/dc44/dc44-animal/maintaining-your-dyson-machine/removing-blockages-from-the-power-floor-tool
The video I've attached should also help you check for and remove any threads, hair or debris caught around the brush bar.
If you'd like further help after you've given this a try, please get in touch with us directly so our experts can talk you through some additional troubleshooting checks. You can reach the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1800 239 766 (AU).
Jan 29, 2014 | Dyson DC44 Animal Cordless Vacuum Handheld...
I have a new Dyson DC44. It has a screw rather than a push button to remove the battery. I bought a spare battery. When I unscrew/loosen the screw, the screw won't come out and the battery won't pull
Hi Mike, it's Jack at Dyson.
Our cordless vacuums including DC44 Animal now include a fixed battery which is not designed to be removable in everyday use. As DC44 offers a runtime of up to 20 minutes of high, constant suction, we've found Dyson owners don't usually need an additional battery to complete cleaning tasks.
The battery is removable if it ever needs to be replaced, but we would advise against attempting to swap the batteries in normal use as the machine isn't designed to be used in this way.
For further advice I'd encourage you to contact our Support team directly - you can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 22, 2013 | Dyson DC44 Animal Digital Slim Cordless...
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
