Question about T-Mobile Concord
How do i open my music files from my sd card?
I switched to straight talk im using my 16gig sdcard and it shows my music is there on the sd card but i cant get open on my phone.
Try using a file manager app like Astro, its free from the play store. Very much like using My Computer on a PC. Navigate to the SD card, select file, and it should open in the native media player.
Posted on May 06, 2014
How to download picture from tablet to sd card?
usually you can find your sdcard under /sdcard or /mnt/sdcard use a file manager such as OI FileManger (assuming Android tablet here)
If it's windows based, then your SDCard will show up like any other disk on the system.
Jan 13, 2014 | Computers & Internet
Unable to get windows media player to load songs onto a micro SD card for use in an LG cell phone. It keeps saying disk is copy protected. I ripped the CDs as MP3. Turned off copy protection. The...
Go to start menu, my computer and leave that window open.
Then go to start menu, my music and leave that window open
Then you can drag songs from music straight to SD card.
Right click on your mp3 file, go to properties, Make sure read only is NOT checked.
TIP: You can copy all files by clicking the first file, then hold the SHIFT key, and then lastly clicking the last file. Then all files will be highlighted.
Aug 02, 2009 | Audio Players & Recorders
Can't transfer my music to LG800g micro SD card. It will go to internal memory only.
you have to download a file moving app or viewing app. it should allow you to copy the music files on your phone and past them to the sd card. This may work but if not you may have to reformat your sdcard and but that will wipe everything on your card. Another solution is to get your phone rooted is what you may have to do giving you acess to move files around better
Oct 19, 2012 | tracfone.com
My HTC g1 is having issues reading my 16gig class 4 sandisk micro sdcard. It worked for a while but after saving a little over 1 gig of files it just stops working properly. I am running cyanogenmod 6.1 ds...
click start control panel administrative tools computer management disk management right click on your sd card select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on sd card select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your sd card select properties then on customize restore Default in W 7
hope this helps
Jun 14, 2012 | Electronics - Others
When I try to put music on the micro sdcard I cant.Then I try format the sdcard and it tells me the sdcard is write protected.
Hello!!
I suppose you are using the card via inserting it in the CAP ( Holder) that came with the card to be able to make it used with card reader.
So, the Micro SD card gets locked only through it's CAP (Holder)
Steps to Unlock :
Insert the card into the CAP (Holder).
Please check the Upper Left side of the CAP (Holder).
There must be One switch which will slide Up and Down.
Push that switch to Upper side. (Pushing to downward will lock while the reverse will Unlock the Card).
Now Insert it to Card Reader to use it.
Hope it Helps..!!!
Jul 06, 2011 | Samsung Propel SGH-a767 Cell Phone
I have a dsi memory card for the pictures and music i got the picturs to work but not the music how do i upload it
For music to work on your sdcard it as to be converted from mp3 files to aac files, the way to do that is thru itunes, you have to download it if you do not have it, when you have done that, play the tracks you want on itunes, stop each track you play then right click and click create aac vesion, make sure when you do that you see it doing it, you will know when it is because you will see it conveting above the track, and when its done you will hear a bell ring after it converted it,their will be two tracks of each, the one being converted, and the mp3 files its being converted from, when you have all the tracks you want, right click them and click where it says show in windows explorer, send all your track to the file, then drop and drag them to your card, you can put them in a music file on your card, thats what i did for my grandson to make it easy for him to find, then pop the sdcard into the side of your dsi, the open the sdcard menu, and then open the music file and their will be your music, easy, hope this helps you.
Nov 17, 2009 | Nintendo DSi Blue Console
How do you play music saved on an SD Card?
1) frm da music on iTunes, right-click,then click on CONVERT 2 aac.another track(identical) should come out.
2)after completing step 1, go 2 my computer nd open the SD card up,create new folder or use da one u used 4 ur other music.
3)after step 1&2 copy nd paste ur song(s) to the folder u had open.hope dis helped
P.S. make sure u converted ur songs 2 AAC(aac) or else it wont work.
Nov 08, 2009 | Nintendo DSi Black Console
Itunes to sd
If you have converted your music on itunes then all you have to do is right click on the tracks you want on your dsi, and click show in windows explorer, when you have them it that folder, put your sdcard into your pc and drop and drag them onto you sdcard one by one, then into the side slot on your dsi.
Jun 09, 2009 | Nintendo DSi Black Console
Camera will not read SD card
1.) Mount your camera
2.) Open your dcim folder in your camera
3.) In whatever file browser you're using (Explorer, Finder, Nautilus, etc) enable show hidden files.
4.) Remove .thumbnails folder
5.) Be sure to empty trash
See if that works.
Nov 03, 2008 | HTC G1
Garmin Nuvi 310
When connected via USB, the unit should connect with activesync as "Mobile Device". Browse this device with explorer and you should see your (formatted) SD card as \Mobile Device\SDMMC\ or \Mobile Device\sdcard\
Simply drag and drop mp3 files to this folder. If you have a card reader in your computer you can move files to the sd card without having to have
the unit connected.
May 14, 2008 | Garmin nuvi 350 GPS Receiver
T-Mobile Concord Logo
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
