Question about Lowrance GPS
My lowrance seems to be overheating, the screen freezes and it shuts down
  • Craig MacNeill
    Craig MacNeill May 09, 2014
    model lms-520c and only seems to do it when suns on it.
2 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: it will freeze and the screen goes black, it also
your laptop is not overheating.. you operating system is pretty messed up.. try to run the recovery disk and format you harddrive. make sure to make a back up of your important files
Posted on Mar 25, 2010
Elite-5HDI Screen is frozen and unit will not shut off.
Hi Thomas
I think your best bet here would be to contact Lowrance support directly I've included the link below.
-Steve
Contact Us
Mar 08, 2015 | Lowrance Elite-5 HDI with 83 200 kHz and...
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
Emachines ET1810 desktop computer randomly powers down for seemingly no reason. Doesn't crash or freeze, just turns off, as if the plug was pulled. Started about 5-6 months after buying.
It could be overheating, and automatically shutting itself down, to avoid any damage.
Did you get the standard 12 month warranty when you purchased the computer? Did you purchase "extended" warranty? If so, contact Emachines, and get them to trouble-shoot and fix it.
Jun 11, 2010 | eMachines ET1810-01 PC Desktop
Possible overheating
The PS3 has an automatic feature to shut down the system once it acquires overheating. The fans installed vary on how much heat is being generated by the system to cool it down. If the screen freezes occassionally try to set the resolution to a lower setting, say downscale from 1080p to 720p as it will make the system's work a little bit lighter and generate lesser heat. Hope it works.
Apr 30, 2010 | Sony PlayStation® 3 (80GB) Console
When my iWAY 500c gets warm the touch screen will
I HAD THE SAME PROBLEM AFTER I DOWNLOADED THE LATEST UPDATE. I RELOADED IT AND NOW IT SEEMS TO WORK OK. GO TO THE LOWRANCE WEB SITE AND THEN TO DOWNLOADS. LOOK FOR THE UPDATE FOR YOUR GPS AND FOLLOW THE INSTRUCTIONS.
GOODLUCK
Jan 27, 2010 | Lowrance Iway 500c GPS Receiver
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Screen freezes
Could be overheating - can you hear the fan working? Try installing temperature monitoring software such as Speedfan.
Oct 25, 2008 | Compaq Presario 700 470024-192 Notebook
Lowrance 500c touchscreen
My iway 500c kinda had the same problem. At first while driving, the screen would go from 3d to always north to always up and be switching screens 3 to 4 times a second. It would finally go back to normal. After about a month of this the touch screen would work intermittently. It finally quit working completely on a trip to Texas. When I got home I called Lowrance and the said they would replace it for $350. I already spent over $600 for it. I took the thing apart and found the grounding screw to the touch screen was really loose. I tightened it and now its working again for now. I am not happy with Lowrance support.
Clane
Sep 05, 2007 | Lowrance Iway 500c GPS Receiver
GPS Logo
100 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
