Question about Vehicle Parts & Accessories
Can't open my peugoet 206 cc when putting the key init
    Problem Solver:
  • 6 Answers
Try passengers door
Posted on May 07, 2014
Peugoet 206 oil low pressure problem
check that you have the right type of oil in the car and that you have enough of it in
Apr 11, 2013 | 2005 Peugeot 206 1.4
I have a peugeot 206 cc and the boot sensor says boot is open when it is closed
central locking isnot working because the boot cant lock change the boot sensor wswitch then central locking will work all good
Aug 19, 2012 | 2004 Peugeot 206 CC
Peugoet 206 cc roof beeping
Put a resistor across the connector leads of the old motor. Something about 1 Watt and about 20 Ohms. This should remedy it- it will look like a motor winding to the onboard diagnostic computer.
Apr 01, 2012 | Peugeot 206 Cars & Trucks
Peugoet 206 my time keeps saying 0:00 every time i turn on my ignition can u help
CHECK THE BATTERY FIRST, IF THE VOLTAGE GOES TO LOW DURING STARTER IS WORKING THIS HAPPENS, CAN BE THE ELECTRIC UNIT ALSO(COMMON FAULT )
Sep 26, 2010 | Peugeot Liberte Cars & Trucks
I have water leaking in from the boot and rear passanger door it is a peugoet 206 02 reg NOT AS LISTED BELOW - 206 DID NOT SHOW AS A CHOICE
May be you need to replace the door and boot rubber seals. Check any gaps between affected area surfaces and if possible carry out the necessary work to stop the leakage. If the problem is still there then please describe in detail when and how i.e in rain from top or bottom side etc etc.
Oct 12, 2009 | 2005 Peugeot 405
I have a peugoet 206 1400cc hdi its really
Replace spark plugs, air and fuel filter. That is ordinary mainteinance.
Ensure that you have spark on 4 cylinders.
Go to a garage and have car ECU (computer) scanned to retrieve error codes. That will tell you where problem can be.
Have vacuum system and fuel pump tested. This is done using a gauge tool.
Have compression tested.
Check O2 sensor, if the problem is particularly bad when engine is cold , also check AIT and MAF sensor.
Sep 21, 2009 | Peugeot Liberte Cars & Trucks
How do i change 12v power / cigarette lighter! in a Peugoet 206
The cigarette lighter is connected to a harness that's being the unit. You need to most likely remove the panel that the cigarette lighter is attached to in order to remove the lighter unit out. Once the unit is out, disconnect the wiring harness to exchange it. I don't know how exactly your lighter will come out
Aug 25, 2009 | 1991 Peugeot 405
Off side signal keeps flashing (Peugoet 206)
probly a bad switch in the steering coluom i had one that did the same thing
May 16, 2009 | Peugeot Liberte Cars & Trucks
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
