Question about Audi Vehicle Parts & Accessories
WHAT IS THE CARE OF THE BENCH VICE - Audi Vehicle Parts & Accessories
    Problem Solver:
  • 7 Answers
Do not pound excessively on it, keep clean of metal filings, rust etc, use a dry lube on the screw that pulls the jaws together, something like graphite, teflon that sprays on and dries works well. Oil will work also but oil collects dirt and after while you need to wash it off and reapply,
Mostly use common sense while using it, the bigger the vise the more abuse it will take, but no vise will take constant beating from a 4 or 8 pound hammer on it.
Hope this helps
Posted on May 06, 2014
1998 ford expedition booster new master cylinder new all disc break new break peddle goes to floor after bleeding hole system
You can bleed the system all you want and STILL have the pedal go to floor unless the master cylinder was bench bled in a vice BEFORE it was put on the vehicle. ALWAYS bench bleed a master cylinder before you put it in service. If you don't, you'll never get the pedal off the floor.
Nov 11, 2017 | Ford Cars & Trucks
I can't seem to get the chuck open to get the bit out
IF YOU HAVE A GOOD BENCH VISE SET THE BIT OR drill in the bench vice so that the tool and chuck is near against the vice with a small space between the clamps of the chuck and the 2 clamps of the benchvice. place a crowbar between the little space between the 3 clamps of the chuck and the clamps of the benchvice , before doing something spray some wd40 inside the clamps of the chuckwhere the drill is in or bit or whatever. and try to pull off the powertool from the bit of drill if its hard to do then also possible use with a plastic hammer against a light benchhammer where the point is on the clamps of the chuck and on every of the 3 clamps Partly, you can beat in turn 3 times on every clamp down the machine from the drill or bit
Aug 24, 2017 | Drills
I need a diagram for d6r starter motor connected to the battery outside the machine
place the starter in a good vice or clamp it securely to a bench
attach the ground wire from the battery to the mounting flange of the starter body
attach the positive terminal to the positive terminal big terminal post that has no wire going inside the housing
touch the very small terminal to the positive terminal post to energize the solenoid and spin the starter
the body has to be firmly clamped or the motor will spin off the bench
Jul 11, 2017 | Cars & Trucks
How to replace nut on end of drive shaft on 352vs sander
If you have a long enough shaft you can grab onto it with a pipe wrench or vice grip while using an open end on the large nut. You may be able to get it into a bench vice as well. These quite often have lock tight on them as well. Heating may help you out but you will have to move quick.
Feb 15, 2013 | Dewalt Tools & Hardware - Others
How to refit a coil spring in a 420
i used a bench vice and has someone help me put it back in
Dec 12, 2012 | Stihl Ts 410 420 Cut Off Saw...
Screw has broken in the presserfoot bar. How can I get it out?
If one side of the head is broken you can sometimes get it out by using some needle nose vice grips or pliers. If it has broken off flush with the bar... you'll need to remove the bar from the machine, put it in a bench vice, use a drill bit for metal drill a small hole and use an Easy Out.
Might be easier to just buy a new presser foot bar and screw.
Nov 20, 2012 | Husqvarna Designer I
The bolt holding brake caliper has a rounded head making it impossible to get off . any idea's ?
vice grips if not cut and drill which is unconfortable and may require a vice on a bench and removal of caliper bracket.
Mar 14, 2011 | 1983 Ford Fairmont
Replace u joint on GMC S15 pickup
You'll need a bench vice for this. A few sockets help as well. Once you get the shaft off the truck, put a smaller diameter socket on one side and a much larger diameter socket on the other and sandwich in a vice. Compress vice to drive the U-Joint through shaft (smaller socket will drive the one side through the other with the much larger socket). Installation is the reverse of removal.
Apr 24, 2010 | 1988 GMC S-15
How do I replace the driver side front coil spring on the suspension
what type of car is it? the strut needs to be removed. you will need a spring clamp and bench vice to compres the spring so you can open the shock top
Jul 15, 2008 | Renault 181 Cars & Trucks
Vehicle Parts & Accessories Logo
69 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
