Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
How to check fan motor funtionality of PFCS1NJXB SS?
    Habit-Forming:
    New Friend:
  • 82 Answers
It probably has two fan motors. One that keeps the compressor cool and one in the freezer compartment that blows cold air out into the freezer and into the frig. You should be able to hear the motor running and feel the air coming out the vents when you open the door of the freezer. The fan runs all the time. If you do not feel or hear, the fan is not working. The one on the compressor, take the cover off the back and you can see if the fan is turning. It runs all the time also.
Posted on May 06, 2014
Carrier 2000 SS AC how or do you lube fan?
Some motors have a small plastic plug on the top at each end of the motor. Most motors today do not have them any more. If the motor is making noise , its bearings are bad , ,,,, new motor needed. Might check motor mount to see if the motor has slipped on it, making contact with nearby metal.
Mar 18, 2016 | Carrier Heating & Cooling
Interior fan does not funtion
if it runs at high speeds it is most likely the heater resister one way to check this is first check fuses if all are good unplug fan motor and using a nine volt battery and jumper leeds jump the fan if it operates your resister is bad but first take a screw driver handle and tap on the motor if fan starts the motor is going out
Mar 25, 2012 | 1989 Toyota Land Cruiser
Kairak modle#krp89s condenser fan and comprssor not comin on
It is possible that your main contactor is defective.,This in connected at the compressor motor and can be detached. This is the starter contactor for the motor . Now check the lines of the fan for continuity. If there is voltage coming to the compresor and not working you will check the contactor and then the motor. get help if you are unable but keep this information for getting a good estimate for the work that your technician gives you. Hope you try this out. Good day
Jul 31, 2010 | Kairak KAI-KRP89S Prep Table 89""L (3)door...
I have GSS25SGP SS with no condenser fan operation. Components very hot, but unit is still cooling. Is this fan shut down a part of the defrost cycle or a fan motor failure? aerolog2
The fan has to run when the compressor is running. Usually does not run during defrost cycle. Could be bad fan motor, or the fan has lost power.
Jan 02, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Secondary fan on impala SS 1996 not operating. fan motor works, new sending unit, new relay installed What else could keep it from coming on?
The PCM controls these fans via certain sensor inputs, ( CTS ) and switches ( A/C compressor for instance ). When relays are removed, both relays sockets should show 12v constant ( battery voltage on "switch side" ). When the key is rolled on, there should be 12v appear in two more places, ("Coil side" ) the relays are then operated by a ground signal from the PCM. ( Powertrain Control Module ) You need a scan-tool to check for fan request, by the PCM. A/C compressor request, etc. If you have any DTC's then repairing them may well fix your problem, otherwise, you may have a faulty PCM.
Oct 22, 2009 | 1996 Chevrolet Impala SS
Air conditioner fan radietor not funtion
Check the fuse and relay. If they are good then replace the fan motor found at most parts stores.Good luck
Apr 27, 2009 | 2004 Nissan XTerra
Engine heatup
Hi,Your car have one auxiliary fan that comes on when you turn the air on if this fan stops working the motor overheat ,there is a fuse and a relay for this fan ,,check both of them first ,if they are good check the fan motor ....
Aug 17, 2008 | 1996 Chevrolet Impala SS
Refrigerator not cold
Could be that the defrost timer has malfunctioned or the fan motor has burnt out. IF you are tecnically inclined you can take out each and check funtionality to eliminate one of them and replace the other
Sep 22, 2007 | Refrigerators
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
