Question about Sharp ELW535 Calculator
Sharp el w531 won't give answers in decimal - Sharp ELW535 Calculator
  • 7993 Answers
SOURCE: How do I use sharp EL W531 to solve quadratic
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Call it disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
Posted on Sep 17, 2009
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Posted on Jun 16, 2010
SOURCE: hi! I am using the Sharp EL-735 and I don't
Setup DSP TAB
then you can choose between 0-9 decimal places
Posted on Jun 17, 2010
SOURCE: We purchased EL-W535X sharp calculator.
on the key pad row above 7-8-9-(-) all the way to the left there is a key that says change with two arrows moving in a cicle press after each answer will change from even fraction to uneven fraction then decimal
Posted on Oct 17, 2011
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
HOW TO GET MY ANSWERS AS DECIMAL PLACE
To change from a fraction to decimal place answer press the fraction button, a b/c.
May 15, 2014 | Sharp el-531x scientific calculator
Sharp el w531 wont give answers in decimal
Press the CHANGE key to cycle through the different views.
If you don't want results showing up as fractions, switch out of the WriteView mode into the Line mode. Press SETUP, select "EDITOR" then "LINE."
If you need a manual, you may download a copy at http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/30_cal/elw531-g-h-ha-w535_om_gb.pdf
May 06, 2014 | Sharp Office Equipment & Supplies
My sharp el-531x calculator is sowing my answers in decimals. how do i solve this problem
If you have a key marked [change] press it to toggle from improper fraction to decimal to mixed number.
If you do not have the [change] key, press the [a b/c] key to change from decimal to mixed number. Press [2ndF] [a b/c] to convert to improper fraction.
Dec 08, 2013 | Sharp el-531x scientific calculator
I have a sharp El 520 W and I always get answers in decimals, is there a way I can change it to standard form?
I am not sure what you mean by Standard. But to toggle display between (fraction/radicals, Pi ) to decimals you press a key marked CHANGE.
Jan 19, 2012 | Sharp Office Equipment & Supplies
We purchased EL-W535X sharp calculator. Want answers in decimal point as opposed to fractions. How do we change this? My son threw out the instruction manual.
Sep 08, 2011 | Sharp Office Equipment & Supplies
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
Hi I have a sharp el-W535 and want to know how to get rid of the fracton in the line editor as the answer so I can get .500 for example
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 26, 2011 | Sharp ELW535 Calculator
I have just purchased the Sharp El-W535 and am unsure of its capability. Will the sharp el-w535 compute the sum of a list of 10 standard deviations? or do the individual standard deviations have to be...
Thank you for purchasing the SHARP Scientific Calculator Model EL-W531/W531G/W531H/W531HA/W535.
About the calculation examples (including some formulas and tables), refer to the reverse side of this English manual.
Refer to the number on the right of each title in the manual for use.
After reading this manual, store it in a convenient location for future reference.
Notes:
• Some of the models described in this manual may not be available in some countries.
• This product uses a period as a decimal point.Displaying calculation results
When possible, calculation results will be displayed using
fractions, r, and ?. When you press U, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers
• Irrational numbers (square roots, fractions made using square
roots) ? decimal numbers
Notes:
• In the following cases, calculation results may be displayed
using r:
• Arithmetic operations and memory calculations
• Trigonometric calculations
• In trigonometric calculations, when
entering values such as those in
the table to the right, results may be
shown using r.
• Calculation results may extend off
the edges of the screen. You can
see those parts by pressing l
or r (depending on whether the left or right portion is
hidden).
Jan 17, 2011 | Sharp ELW535 Calculator
Sharp ELW535 Calculator Logo
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
