Hi can any one help i need to find the serial number for ic on lcd dvd
The ic has blown on t con board and i carnt see the number to order new one can any one help point me to the right place thank you all mark
  • Mark Miller May 08, 2014
    wharfedale L1911wc lcd dvd 19inch hi eletronic repair ill open the tv up and see were about the ic is on t con board i did look on mosaic link i put the make model of my tv it said theres no links for that tv
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
What is the brand name to your TV? To which section circuit IC number do you want to know? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 06, 2014
  • 3 more comments
  • The Knight
    The Knight May 08, 2014
    Hi mark Even though you distinguish the number of IC, whatever it may be; you can\'t replace it by any way. It is a surface mound device, in short and SMD IC. You only can replace the T\'Con board as card basis. So, take a look for it. You can see the details of the number that printed on the board, and only with that part number, you can even search for its availability.
  • Mark Miller May 13, 2014
    hi there can you tell me why i carnt replace ic on t con board wharfedale 19"
    hi next to the t con plug theres a white plastic thing on the right thr ic right next to it is what im talking about t con is on a ribbon so i can take if so why carnt i replace it model number 190M
    sorry number is 190M254L04
    even tryed e bay none on there ? any one know were to pick t con or the ic im talking about
  • 718 Answers
SOURCE: Is the T-Con board the LCD controller? What is
Website shopjimmy.com has Sony LCD Controller 400WSC4LV0.4 for the KDL-40S2000. Other sites may also have it.
Posted on Mar 06, 2009
jerryg50
  • 1689 Answers
SOURCE: LN-S4692D 46 in. HDTV T-Con Board
This answer is generic:
Most of the time they use fuse resistors. Sometime there a number of them. They are not all the same. This is not a simple fuse. It is a resistor combined with a fuse. You would need the service manual to properly identify the fuse resistor and have its spec. You would then have to order the correct one from a parts distributor. If it cannot be replaced generically, the original would have to be ordered from the manufacture.
In any case, if there is a blown fuse on a power supply board you can be sure that there are failed components that are most likely shorted. This would mean that the board would have to be troubleshooted to find and replace the defective parts.
Most of the circuit areas and the boards in these sets are not supported to be serviced at the component level. They change the defective boards as in the same process as servicing computers.
As for the heat problem, if you can find someone who is technically very competent, maybe he can custom install a fan for the area that is getting heated. It should be possible to find a 12 volt source from the main power supply to run a small fan to assist for extra cooling.
If you have your set in a cabinet, or if it is wall mounted it may run hotter. We found that sets that are wall mounted tend to fail more often because the heat can reflect off of the wall back in to the set. Cabinets tend to not allow the heat to dissipate as well as out in the open.
Jerry G.
Posted on Jul 26, 2008
  • 182 Answers
SOURCE: MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Posted on Jun 03, 2010
fosg2000
  • 229 Answers
SOURCE: Need Parts for sharp Lc32av22u / SN 704827112 A
hi, here you can get all that you need :
http://toddstoyz.com/cls/index.php?searchStr=LC-32AV22U&_a=viewCat&Submit=Go
ae me please
Posted on Jul 30, 2010
chesterpendi
  • 195 Answers
SOURCE: Sony Bravia KDL-46W4100 T-CON replacement
yes
Posted on Jun 25, 2012
Why is my TV burning through T-Con boards? Ever time I replace one, it works for 2 hours and then I lose picture again. I've replaced 2 so far.
Hope the TV have problem with the either power board or the lcd panel. Try to check the power supply is its produce correct voltages mentioned on its connectors if you need help then check the video for that. if the power supply finds ok then you have problem with the lcd panel. In lcd panel there is a some ics which used as the driver of the pixels. the tcon sends data to these ics. and if any onf the ics draws more current from t con board then it can dame the t con. They are not replaceable one ,its integrated to the panel. if its faulty then you have to go for a new panel for that tv. And it would be a expensive repair.
Testing LCD TV Power Supply BoardsSTEP BY STEP
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
http://electro-medical.blogspot.com/
Nov 11, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 03, 2015 | Samsung Televison & Video
My TV has vertical lines
hi,
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
Sep 25, 2015 | RCA Televison & Video
Hi there ive got wharfedale lcd dvd 19" and on the t con board a ic has blown but i carnt see number
It is likely a proprietary wharfedale chip and no info will be available. you will need to purchase a board assembly or replace the device.
May 06, 2014 | Creative Technology SBS 245 2 Speakers
Hannspree 28 Inch Lcd Tv Model Number HSG1075
Check its Chroma section circuit for fault. Most possible cause is damaged chroma IC.
Aug 09, 2012 | Hannspree Televison & Video
VERTICAL LINE ON LCD TV
You didnt specify the brand and model number of your TV any way the above mentioned problem can occur when the T-con board of the lcd Tv have some problem. There is no repare possible with these boards. The t-con board controls the pixels of the lcd panel. When any one of the out put from the t-con is faulty then the specific pixel or row of pixel will be absent. That's we see as lines or missing pixels. You can find the T con board normally in the bottom centre or top centre of the LCD tv covered with metal cover or aluminium foil. There will be a part number in the board. You have to replace a board with the same part number.
Some time there will be some loose contact in the connections of these board can cause these problems. Before going for a new board remove all the connection to the board and then reconnect it. If then also the problem is there then you need to replace the t con board. This is a common problem to the lcd TVs. Normally t con board will look like one in the picture. If you need any more assistance fell free to contact me through fixya. Next time when you post a question remember to add the make and model number of the product.
Dec 24, 2011 | Televison & Video
Vertical lines on lcd hdtv
You didn't specified anything about the make and model number of your tv. Any why the above mentioned problem can occur when the T-con board of the lcd Tv have some problem. There is no repare possible with these boards. The t-con board controls the pixels of the lcd panel. When any one of the out put from the t-con is faulty then the specific pixel or row of pixel will be absent. That's we see as lines or missing pixels. You can find the T con board normally in the bottom centre or top centre of the LCD tv covered with metal cover or aluminium foil. There will be a part number in the board. You have to replace a board with the same part number.
Some time there will be some loose contact in the connections of these board can cause these problems. Before going for a new board remove all the connection to the board and then reconnect it. If then also the problem is there then you need to replace the t con board. This is a common problem to the lcd TVs. Normally t con board will look like one in the picture. Of you need any more assistance fell free to contact me through fixya. Next time when you post a question remember to add the make and model number of the product.
Ajin
Dec 17, 2011 | Televison & Video
Screen turned white, only sound to hear
It tuns white because he T-CON board is not working due to blown fuse on the board or it is no getting the voltage from the main board, you can check for voltage at the T-CON fuse, you need to find out if the T-CON board is part of the LCD panel assembly or it is its own assembly, if it is part of the panel, thne it will not be worth fixing since the new screen will be needed.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 12, 2010 | Daewoo DSL19T2WCD 19 in. LCD TV TV/DVD...
We have a sony bravia tv after the tv has been on an hour or so a vertical green line appears periodically on he right side also shadows appear around images too. They replaced the whole pannel and the...
There is a board on the LCD panel towards the top of it that is called the T-Con board and is sometimes included with a new panel. If it is not then they had to transfer the old T-con to the new panel. If this is the case then most likely the T-con board needs to be replaced. The servicer will have to verify and order by model and serial number as there are usually different part numbers for the T-con board. Please take a few moments to rate my answer. Thanks...
Nov 23, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
