Question about Health & Beauty
How to unlock my seat on my150cc gas scooter.
  • 3 Answers
Do you have any other information like make,model, or pics that you could provide?
Posted on Aug 08, 2014
Where is gas tank location on a 2011 50 cc sunny scooter.
Looks like the fuel cap is behind the seat, so most likely the fuel tank is under the seat.
A manual is available here:
Welcome to Sunny 50 Scooters
May 12, 2016 | GAS Motorcycles
I have s141 scooter how do i take the seat off to get to batteries
hi the seat and small; shaft on bottom of seat will come out if u lift it up and unlock seat swivel lever at the same time ..if it wont lift out turn scooter on its side it will come out a lot easier ,,,,,,,,,,, good luck
Mar 17, 2016 | Health & Beauty
I have apparently an older scooter. I cannot figure out how to remove the seat to replace batteries. Does not have the lever on the right side of seat.
hi most scooter seat just lift out without removing bolts just unlock youre seat swivel lever and the seat should come out of the shaft good luck
Mar 17, 2016 | Invacare Pronto M51 with SureStep
How do you remove the seat from a derbi atlantis scooter?
feel around and under the edges of the seat and there will be a tag that you lift/press to release the seat
May 06, 2015 | Derbi Motorcycles
Does anyone by any chance know what oil goes in a qingqi 49cc scooter. It has it's own little reservoir inside the seat panel. Can anyone tell me what does it take. Confused and don't know.
Hello, Qingqi. I found this article that says SJ10W-40 is best for a 49cc gas-powered scooter. http://www.ask.com/vehicles/type-oil-use-49cc-gas-powered-scooter-e2ec930521cd0a6a
Mar 28, 2015 | Qingqi Motorcycles
How to unlock my seat on my 150cc Baboon gas scooter.
quite probbably with the ignition key.
May 06, 2014 | Motorcycles
How to unlock the seat on 150cc gas scooter.
Look around below the seat, usually on the left side. There's often a lock there and if you insert the key and turn it the seat latch should release. Some scooters unlock the seat latch by turning or pushing the key a certain way in the ignition.
I have a PRIDE scooter. It is a Victory model but I don't have any serial number or exact model #. It turns on, goes a little and then "bucks" ir stops completely. When I take out the key and...
1)Make sure the battery's fully charged..
2)Your brake lock and unlock leaver under your seat..be sure its totally engaged in the locked position in other words ''all the way pushed down''.
3)Take the shroud off the back, this can be done by removing the seat, hold the seat leaver up towards you ,Now you should be able to rotate the seat when you have lifted that leaver when it does rotate lift up the seat it will come off.now that the seat,the shroud are off. you will be able to see the battery's make sure the connections are good and tight...
4)Tilt the scooter over on its side there is a grayish white cable this is your front-to-rear cable follow it from the front to the back ,make sure there is no cut or broken spots'which would be a spot on the cable that looks as if its been scraped against the ground .If there is a brake in that cable it will need replacement.
* Put the shroud and the seat back on the scooter if everything checks out ,Get on the scooter turn the key make sure that needle goes all the way to fully charged mark go slow tap the top of the console if it stops faster than it did before or doesn't at all your looking at a new key switch.
hope i was helpful good luck.
Jan 16, 2011 | Pride Mobility Victory 3 Wheel Electric...
How do you remove the seat on a Pride Jett 2 electric wheelchair?
On all the pride chairs that I have worked on, you just rotate the seat from straight ahead a little to unlock it, and then pull up while turning it back and forth.
Jan 02, 2009 | Pride New Mobility Celebrity 3 wheel...
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
