Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Our ice maker has rust on ice sometimes and can't understand why or how to fix
    Novelist:
  • 150 Answers
You would need to remove the ice storage bucket and dump the ice, check the corkscrew wire in the bucket for any signs of rust, some auger wires were chrome plated and not aluminum. If no rust there, remove the ice maker it's self and check the ice making mold for signs of rust. Replace all rusted parts found. Pleazer Appliance...
Posted on May 07, 2014
RUST ON REFRIGERATOR DOOR
Hello friend, thank you for your post!
I understand that there is rust on the door of your Frigidaire refrigerator. Typically, rust is not covered under the warranty and in most cases the door will more than likely need replacing. If you would like to get a part number and availability I would recommend contacting the manufacturer directly. If you would like for me to locate that information for you could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your fresh food side. I look forward to assisting you. -Matt
Oct 14, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
I have a GSS25WGTA GE ice maker. The arm on the ice maker won't reset after it dumps ice. I have to manually do it every time. Is there an inexpensive fix for this?
If you find a way to add a weight to the arm to make it drop down it cheap. what may work is a peice of metal attached to arm.IT MUST be stainless steel so it doesnt rust in the freezer with all the moisture then all your ice has rust in it
other than that icemaker has to be replaced
Aug 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is slow to make ice. It dumps sometimes. it builds a large mountain of forzen ice that mounds up under the tray. even though we remove it it always comes back. ice is also runnig down the...
Ice maker problems are almost always a problem. Sometimes I will locate an issue and fix it and then it will work for a short period and then break again. So, now I just replace the ice maker as a general rule. This is much more likely for success. However, the replacement ice maker is often not an exact match. And again, the this and the that sometimes causes problems. I will never accept a new customer on the grounds that I am going to fix their home ice maker. Make sure the ice machine is getter water like it is supposed to. Check the filter and the tubes. If the problem persists, get a new ice maker. If that ice maker angers you, get some ice cube trays.
Jun 11, 2011 | LG LSC26905TT Side by Side Refrigerator
Everything's fine with the ice maker, except that the little door releasing the ice into the glass will not open. I've had it apart, moved rubber parts out of the way, and it still will not release the ice...
there's a solenoid and a plunger that opens the door shute,part number WR62X10055.unplug the machine,pop off the frame that goes around the dispenser,once you pop that off the rest is self explanatory.you'll see the solenoid and the plunger piece most likely will be rusted up or sometimes stuck in the solenoid.the hardest part is removing the frame without cracking it.good luck
Jan 23, 2011 | Hotpoint HSS25GFP Side by Side...
Ice maker suddenly stopped working. It makes strange noises intermittently, sometimes sounding like a Geiger counter. It no longer draws water. What can I do to diagnose & fix the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 10, 2010 | Refrigerators
Need 5qt can for sterling icecream maker
I have used can from a unit I have that has a broken lid. Not rusted through but some spots. I will part out if interested. Motor still works.
Jul 06, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Sometimes there are black particles (looks like black flakes) in the ice from my icemaker. Do you know what is the likely cause for this? Thanks
put a filter in the water supply line going to your ice maker more than likely it is rust from the inside of the water lines
Apr 22, 2009 | Refrigerators
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
