Question about Creative Technology SBS 245 2 Speakers
Hi there ive got wharfedale lcd dvd 19" and on the t con board a ic has blown but i carnt see number
Dos any one know what it is or how to find out so i can order new ic for it thanks mark
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 183 Answers
It is likely a proprietary wharfedale chip and no info will be available. you will need to purchase a board assembly or replace the device.
Posted on Jun 03, 2014
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 03, 2015 | Samsung Televison & Video
Hi can any one help i need to find the serial number for ic on lcd dvd
What is the brand name to your TV? To which section circuit IC number do you want to know? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 06, 2014 | Televison & Video
I have a Samsung Syncmaster 930bf monitor, when I turn it on, I can see only white. Backlight is working but there is no picture. I tried both video inputs, no difference. Capacitors on power supply part...
It sounds like the ribbon vable between the logic board and the T-CON board on the LCD panel may have come off or it has blown fuse on the T-CON board, or not getting the 5Vdc from the LOgic board to the T-CON board due to bad 5vdc switched transistor that supply the voltage to the T-CON board.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Samsung SyncMaster 930BF 19" LCD Monitor
I have a single purple/pink line running vertically on my 40 inch samsung lcd tv 720p it goes away usually after awhile but comes back ive tried just about everything i know to make it go away permantly...
The tv board that call the T-CON decodering board is the caused.This board sit at the middle of the bottom of the LCD screen panel.Check the cableling connections or the T-CON decodering board is dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Mar 29, 2011 | Televison & Video
Last the picture . have a white or gray screen. It was working fine one minute then the picture was gone. It's not the PC ,I check.
Gray glowing screen can be due to bad T-CON board (blown fuse, bad IC), or the main baord is not sending the 12vdc to the T-CON board. See my giudes.
Basic LCD monitor troubleshooting guide:
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 23, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Tv have white screen no picture
Tuner board is dead.That the board,where the brocasting signal cable plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 10, 2010 | JVC LT-40X776 40 in. LCD HDTV
Screen turned white, only sound to hear
It tuns white because he T-CON board is not working due to blown fuse on the board or it is no getting the voltage from the main board, you can check for voltage at the T-CON fuse, you need to find out if the T-CON board is part of the LCD panel assembly or it is its own assembly, if it is part of the panel, thne it will not be worth fixing since the new screen will be needed.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jul 12, 2010 | Daewoo DSL19T2WCD 19 in. LCD TV TV/DVD...
Can't find replacement part
There is a supplier that supply the spare parts of Wharfedale. You can ask them for this.
The link is given
pltv.org.uk/wharf.htm
Jan 28, 2010 | Televison & Video
Creative Technology SBS 245 2 Speakers Logo
61 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Jim Y
Jim Y
aliasger yq
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
