Question about Toto Toilet Onepiece Ultramax MS854114SL.12
How to replace a Toto Power Gravity Anti Siphon 528?
How do you release the old siphon piece?
3 Suggested Answers
  • 299 Answers
SOURCE: I have a toto ultramax. the water keeps running
It is a little stiff but you won't break it. Just turn the cap counter clockwise (left) about an inch and it'll come right off. Put the replacement cap on by doing the reverse and it should be good to go. I have 7 of these toilets and they all needed cap replacements within 2 years. When you change it be sure to flush any sedimant out of the valve body as that's what usually causes the problem. Once you have the cap off hold a small pail or large cup upside down over the valve body and turn the water on for a few seconds. The cup will keep the water in the tank and the body will be cleared of sediment. After changing a couple and on the recommendation of the local Toto distributor I decided that it would better to just replace the whole valve with a FluidMaster unit (about $8 at Home Depot). The Fluidmaster units have been working fine for 6 years. It takes less than 20 minutes to replace the whole valve but is, of course, a bit more work than changing the cap.
Posted on Apr 18, 2010
SOURCE: My toto power gravity siphon
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Posted on Oct 26, 2010
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
Faucet leaks through anti siphon valve
They make a repair kit for the anti siphon valve.Pop cap off (be careful not to break clips on anti siphon cap) remove old anti siphon valve and put in new replace cap problem solved.It screws out.
Jun 04, 2011 | B&K Plumbing
Korky anti siphon 528 is leaking, water is high and leaking in drain pipe
If the water is reaching the tank overflow tube, the float valve is not stopping it fully. If the valve is new or not too old and you have instructions or know how to disassemble it, you can flush it to ensure there is no debris in the valve or on the seat. Although the manufacturers recommend this, I have never found anything on the seat.
If you can't do this, a new float valve assembly must be installed.
Gary
Feb 26, 2011 | Lavelle Industries Korky& Universal Toilet...
When I try and siphon gas from my 1991 Olds Cutlass Supreme, I can't seem to get the hose all the way into the gas tank. Is there some type of restriction that hinders siphoning?
You can,t there is a ball inside that will let fuel in Its there so if the vehicle rolls over the ball moves beck to stop the fuel spilling out of the tank You would need to disconnect the fuel inlet hose at the tank to siphon fuel from the tank
Dec 05, 2010 | 1991 Oldsmobile Cutlass Supreme
My toto power gravity siphon won't stop running. Suggestions as to how to fix would be greatly appreciated. Cheer, Mark
Oct 24, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have a toto ultramax. the water keeps running in the tank, even when its over the level of spill valve. i've looked at various websites which say how to repair, but i've got the most basic question...
Apr 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Toto toilet Power Gravity intermittently running
Did you replace the flapper with a genuine Toto replacement flapper? If you didn't, they are slightly different. Toto toilets are fantastic but you do need to use OEM parts for repair.
Mar 13, 2009 | Toto Washlet S400 for Power Gravity...
Toto Toilet  Onepiece  Ultramax  MS854114SL.12 Logo
65 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
