Message Hp 6500 Printer all in one says, broken pipe won't print from the computer ... every thing else works ok
  • Office Equip... Master
  • 2,826 Answers
Try shutting the computer off, unplug printer, and start it all up again.
How is the printer connected? check the cable and confirm it's plugged in fully.
Posted on May 07, 2014
Testimonial: "Jay I tried all this and it printed one page perfect then the black faded to pale blue then faded to no print. It will do this again if printer is not used for a few hours. This all started after there was a paper jam when printing. But I keep coming back to why does it print Ok when just on the copying phase of the printer??? Thanks for the suggestions, it's made to work. Is there a separate ink supply pipe that can be bent or broken going to the print heads for the print application alone from the computer???"
  • Jay Plesset May 07, 2014
    I'm not intimately familiar with your printer, but HP printers in general don't have ink running through pipes, except for the 24" and larger plotters. It's possible that the paper jam damaged a print head, but unlikely. It's possible that you are low on ink, or that the heads need cleaning. I would try a nozzle check/clean to see if that helps. Now that your computer can talk to the printer, that's the hard part...
SOURCE: Printing Quickbooks voucher checks with HP 6500 officejet printer
i have nearly the same problem and I'm going to continue to search and write 6500 voucher printing problem
Posted on Sep 22, 2009
Evildice
  • 217 Answers
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Posted on Sep 24, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
  • 145 Answers
SOURCE: HP Officejet 6500 E709 (new printer) will not
Hi ladarlak
There is no full feature driver for Windows 7 yet. Meanwhile HP have printed a workaround at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796879&lc=en&dlc=en&cc=us&lang=en&product=90764
Posted on May 09, 2010
My HP 6500 wont print black ink. It's like a very very light grey and I can't see it. Tried 2 new print cartridges and no luck. Please help.
The HP 6500 printer has separate in cart and print heads. The light print you are getting is because the print head in clogged with dry ink. First thing to try is to go into the printer software on your computer and do a print head cleaning procedure, this will take a few minutes to finish. You may have to run this several times to clear out the dry ink. If this does not solve the problem when you will need to get a replacement print head, the part number is CB868-30002
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
WON'T PRINT TO MAXIMUM PRINT AREA
You should change the margins in the word document before you print to 0.5 mm on all sides and remove header and footer.
May 02, 2012 | HP Officejet 6500 Wireless All-in-One...
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I am using an hp officejet 6500 and I keep getting an error message 0x61011bec, what can I do to fix this problem?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you print on both sides of a piece of
On the computer:-
Click on start-->control panel-->printers and faxes or printers-->right click on HP Officejet 6500 Wireless All-in-one Inkjet Printer.--> choose the print preferences option. Now you will see in the list of options there is some thing called depluex printing --> Select it and hit the apply button and then try printing.
It is actually a setting under the printers properties which needs to be switched on. Once you switch it on it will start working.
Let me know if it works.
May 07, 2010 | HP Officejet 6500 Wireless All-in-One...
My printer worked fine until Windows 7 downloaded something supposed to make printers work even better.Now Word, Excel and Adobe files don't print. There is no error message. I hit the print button and it...
Contacted HP Chat support. After investigating a bit they had me add a new printer using the virtual USB port and designating that printer as the HP OfficeJet 6500 E709A series. I did so and made that the default printer. Immediately Word, Excel and Adobe documents were once again printing.
Jan 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
Hp 6500 misaligns printing on labels. can print same labels on other printers.
I determined that if you set the paper type to
" Borderless A4" (in printer properties/preferences- just tick the "borderless" box) then all works OK.
Sep 02, 2009 | HP Officejet 6500 Wireless All-in-One...
jasbo
jasbo
