Question about Vivitar 283 Flash
I have a nikon d3200/vivitar 283/wein voltage adaptor/good sync cords and still no flashoutput,help rick
    Top Expert:
  • Vivitar Master
  • 6,702 Answers
Just to exclude anything faulty, start with the flash on the camera and check if it works. Also check the camera settings. On your Nikon you can chose flash off. Don't do that. If you get the flash working on the camera then you starts with the extension cord and it still should flash in the same conditions.
Posted on May 08, 2014
  • 4 Answers
SOURCE: wireless flash trigger for vivitar 283
I purchased the Wein Slave Foot. The metal foot is designed to repair the plastic foot that, apparently, is prone to breakage. Mine is not broken, but I purchased the Slave Foot because the blurb stated that it would make my unit serve as a remote slave.
The setup works fine with my Sony A700 using either the built-in flash or in combination with my proprietary external Sony flash.
I have just purchased another used 283 and will be ordering the Wein Slave Foot from B&H in the morning.
Caruso
Posted on Jan 03, 2009
SOURCE: Battery holder for Vivitar 283 is broken. Can I get a replacement
I think there are some listed on Ebay-check it out.
Posted on Jan 30, 2009
SOURCE: Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Posted on Feb 22, 2009
  • 149 Answers
SOURCE: what is the trigger voltage for a 283 bought in
take multimeter and see the voltage must be not more then 5 to 6 only you can check the voltage near the hot shoe or cord
Posted on Oct 28, 2009
videotransmi
  • 105 Answers
SOURCE: my vivitar 283 flash won't turn on. I checked the
Check the contacts for the battery to make sure they are clean and shiny. Then insert 4 brand new AA batteries observing the correct polarity and try again. Also check your users manual to be sure all of your setting and connection to your camera is correct.
I hope this was a help to you and good luck!
Posted on Nov 13, 2009
I have an old Vivitar 215 flash, still working. Can I use it with my Nikon D3200?
Not without using something like the Wein Safe-Sync to isolate the flash from the camera. The flash's trigger voltage can otherwise fry the camera.
Nov 10, 2012 | Vivitar Auto 215 Flash
Can I use a Vivitar 2000 with Nikon D90.
NO! The trigger voltage on the 2000 is much too high. It will fry the circuity on the D90.
If you really want to use it, you'll have to use something like a Wein Safe-Sync to isolate the two.
May 26, 2012 | Vivitar 2000 Flash
What hot shoe/sync cord do I buy for my Nikon D40x to operate my 283 on a camera bracket?
Nikon AS-15:
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213519300
Oct 29, 2010 | Vivitar 283 Flash
Can you use a vivitar 285 flash with a nikon D90 , if so do they still sell the cord that connects to the camera for off camera flash??
You can use the 285 with the D90, just don't do it without something isolating the two to prevent the trigger voltage from frying the D90. You can use something like the Wein Safe Sync
( http://www.weinproducts.com/safesyncs.htm ) for this.
As for an off-camera cord, you can use something like the Nikon
SC-29 ( http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213505500 )
Sep 23, 2010 | Vivitar Cameras
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
What is the trigger voltage for a 283 bought in 1996 and is it safe to use on a nikon d80
Oct 24, 2009 | Vivitar 283 Flash
Jan 06, 2009 | Vivitar 283 Flash
Vivitar 283 flash will not work on camera.
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
Good luck
Aug 29, 2007 | Cameras
Vivitar 283 Flash Logo
89 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
