Question about Music
Marshall mg sound cuts in and out on all channels clean crunch od1 od2 all the them you cAn barely hear the guitar and it gets really fuzzy or hairy when I turn it up and play like beak is in and out really fast or something
  • 93 Answers
Jumper the power amp in jack to the preamp out jack [or effects send jack to the effects return jack]. There may only be oxidation in the contacts of these jacks. If the normal sound level comes back-either clean the two jacks or have them replaced.
Posted on Nov 23, 2014
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Check out your input grounds on your amp
Posted on May 13, 2014
  • david jones May 13, 2014
    check out your input grounds on your amp
5 Suggested Answers
  • 1138 Answers
SOURCE: My problem is that the clean channel doesn't work.
Here is the schematic:http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf There are a few possibilities.The jack for the footswitch for channel changing JS1 might be faulty. Zener diodes 1 and/or 2 might be faulty. Switch 2 may be defective. TR1 might be defective. IC 4 or 5 might be defective.Start with the channel switching circuitry testing in the order I gave you. Check the actual clean channel circuitry to see if you actually have a clean channel anymore. Before you do any of this make sure you know enough about troubleshooting and have at least a good VOM and are familiar with safety procedures. The filter capacitors in this amp store enough charge to kill you. A cheat to partially discharge them without damaging the amp is to unplug it from the wall while it is hooked up to the speaker cab you are using while it is on at a very low volume with a guitar cord plugged in. Make sure you use exact replacement parts if you tackle this. They don't have to be from Marshall, they just have to be exact electronic equivalents from a quality manufacturer installed correctly. I would recommend that if you have no experience or are at all unsure of the repair to take it to a Marshall dealer to have it done. Please rate me if this helps.
Posted on Nov 29, 2009
  • 10 Answers
SOURCE: i've had my marshall mg 50dfx for 3 months and it
Play around with your placement and where you are compared to the amp. I have a line 6 spider jam and I was getting pissed everytime I went into guitar center b/c theirs had more bass than mine. Then I realized that I put the amp beside me when I play but I play infront and over it when I go there. Have you ever noticed how much gain you lose when you take it outside compared to in your room. I would just look up the owners manual and see if you are missing anything. Check the fuse in the back too. If you clean isnt "that" clean and your overdrive is sucking then maybe the fuse is on its way out. Only $1 problem though. good luck
Posted on May 25, 2010
  • 5603 Answers
SOURCE: marshall jvm 410h i'm getting
Dampen the strings of your guitar. If feedback disappears, then you need to move the amp so it can't resonate the strings of the guitar. OD1 and OD2 WORSEN the chances of the feedback into the strings. When this occurs you can often see the strings vibrating without the player picking them.
Posted on Nov 23, 2010
guitarmanjoe
  • 336 Answers
SOURCE: Marshall mg100hdfx loud fuzz and distortion and no guitar sound
I would think the other way, IF you hear fuzz or hear anything at all, your input is fine, wiggle the speaker plug around and listen for changes. You probably have a dirty socket on SPEAKER OUTPUT.
Posted on Mar 08, 2013
Marshall MG100HDFX footswitch toggling - bypassing?
I once used uART & some latches to decode & hold the difference between "odd & even" midi program changes. Then used the output to switch a relay in a twin necked guitar to change between necks as it were in response to a midi pedal. Perhaps you could do something similar? Else get a Studiomaster MA-36 midi analyser & hack into it to use one piece of midi data (from across an LED?) to switch channels on your amp? Good Luck!
Jan 16, 2017 | Marshall Music
What would cause my Marshall Mode 4 amp to not change channels?
That can be caused by a faulty switch contact. I presume channels can be selected manually.
Aug 05, 2014 | Marshall Amplification Marshall AR-AM4,...
Marshall troubleshoot
First check the preamp valve in that curcuit
Feb 26, 2014 | Marshall Amplification Music
I have an MG30 FX amp. In manual mode when I change channels amp seems to work incorrectly. E.g. i select clean, then set up delay. When I change to crunch then, there's no delay, though from the manual I...
Typically ONLY one effect will be active at a time unless there is a specific mixed effect available. The gain levels between the different effects are often not too consistent. In summation, this is probably the nature of the beast.
Mar 12, 2011 | Marshall Amplification Marshall MG4 Series...
Marshall jvm 410h i'm getting loads of feedback when i use od1 or od2 orange or red mode
Nov 22, 2010 | Marshall Amplification Marshall JVM Guitar...
I've had my marshall mg 50dfx for 3 months and it doesn't sound right to me because the overdrive is just barely different to the clean channel and doesn't have as sharp as sound as other mg50dfx models
May 09, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
My problem is that the clean channel doesn't work. The OD1/OD2 channel works just fine but I'm not getting any sound out of the clean channel... any ideas?
Nov 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Check your input (guitar signal).
Also, check your gain and volume levels.
Make sure that you have a reliable, steady, and clean power source as well.
If the problem persists, contact the store from which it was purchased. There are a lot of things that can go wrong internally with the cheaper Marshall models.
Jun 25, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
79 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
