Question about Dryers
Samsung gas dryer
Gas was temporarily shut off. After it was turned on again, the dryer does not heat and there is a strong smell of gas. Is their something I need to do to get the igniter working again? The room has been aired out.
  • Karen Reznek
    Karen Reznek May 06, 2014
    A second attempt to run it worked. Laundry dried.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
Nothing to worry about . The problem you had was there was air in the line. Here's how it works. The igniter heats up then the gas valve opens. You had air coming out so it did not light initially . The air was followed by the gas supply but at that point the igniter was already cooling down. When you tried a second time the gas line was purged of all air hence normal operation.
happy drying.
wayne
Posted on Jun 29, 2014
  • 18 Answers
SOURCE: gas smell from dryer
your igniter needs to be replaced.
Posted on Feb 04, 2007
SOURCE: Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Posted on Feb 16, 2008
  • 14 Answers
SOURCE: dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Posted on Jul 25, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
TheMobilian
  • 8220 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
Posted on Mar 14, 2009
Strong fumes from new frigidaire gas oven.what should i look for
If it smells like gas Shut the gas off outside call installer, or
gas company. If it doesn't smell like gas, most likely it's the "new smell" caused by the heat. If you have a kitchen vent fan turn it on. If it persists Call the installer or dealer. No action by them? call the mfg customer service number in your owner's manual. It's possible something was left in the oven burner area that shouldn't be there.
Feb 27, 2015 | Frigidaire Kitchen Ranges
Is it normal to get a faint gas smell when you hook up you'r gas dryer?
Absolutely. Your dryer runs on gas, and the gas kicks on when the heating element engages. It should be so faint though. If you smell it continuously then check your connections with soapy water, if their is a leak then shut off the gas and try using soap pipe dope, or teflon tape on the threads, then recheck. My guess is its the regulator near the heating element. Good luck
Feb 21, 2011 | Kenmore 77632 Gas Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a kenmore 80 series gas dryer and the gas line to it was recently turned off temporarily and now it won't get gas to heat up now that it is back on. Is there something wrong w/ the pilot mechanism??...
When gas is shut off, even for a short period of time, air enters the gas line and must be purged before the pilot will light.
Hold down the pilot light button longer than you think you should have to, then wait about five minutes to clear any gas that might have escaped then try again to relight the pilot. You may need to do this two or three times in five minute intervals.
Hope this was helpful.
Oct 10, 2009 | Kenmore 73952 Gas Dryer
GE Dryer has gas smell inside.
i would not play with this problem , the lines and the seals in the dryer must be checked .. by a proffesional ... hope u dont get a spark , get this checked imediatley
Sep 26, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Gas dryer won't heat after a move.
Make sure the vent is not blocked. Run the dryer and feel for a strong air flow at the vent outside. The most likely cause is flexible vent hose used on the dryer is squeezed behind the dryer, blocking air flow. Don't use flex hose. You may have a lot of built up lint in the dryer vent pipes also, which would need to be cleaned out. Also, make sure you are still using the same type of gas. (natural vs. LP) If different, dryer would need to be converted for proper opperation.
Jul 19, 2009 | Dryers
Dryer has gas smell, whirlpool lgn 2000w gas dryer
Hello Tuna59,
I would strongly encourage you to identify the source of the gas leak as soon as possible. To do this, you can buy a product at most home depot or lowes department stores called SNOOP.. It is in essence..soapy water with a dauber in the cap. You use it by dunking the dauber in the solution and then putting the solution over gas piping joints. If it bubbles up at all..chances are that is where you have a small leak. You may or may not want to tackle that repair yourself since it poses personal risk if you don't know what you are doing. A build up of gas vapor in a confined space is very very dangerous and only needs a small ignition source to explode so please be careful. Probably a good idea to do all your troubleshooting ( if you decide to do this on your own ) with the windows open in that area. Do not use a fan or any other ignition source to move air/gas. Be careful.. and good luck...
Regards,
Rick
Nov 24, 2008 | Kenmore 63942 Dryer
Gas smell from dryer
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
Top Dryers Experts
