Question about Intel Pentium 4 515, 2.93 GHz (JM80547PE0771M) OEM / Unboxed Processor
Does intel pentium 4 supports other rams like dynet or not
  • Intel Master
  • 2,826 Answers
The memory support is set by the motherboard you have your processor installed in. Pentium 4 is pretty old, and it's gotten hard to find memory for those.
Posted on May 07, 2014
  • 99 Answers
SOURCE: about processor
From what you posted, your processor uses socket 478. You could pop it into any of these micro atx boards
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130178
Posted on Jul 26, 2008
preachw996
  • 1179 Answers
SOURCE: i have intel pentium 3 with 128 ram. how can i increase ram memor
To upgrade your RAM you would need to know what type of RAM your motherboard supports. Once you have this info you can then check online who sells the RAM modules. Once you make your purchase you then can remove the old modules, replace with the new modules & reboot. Hope this helps & please remember to rate my answer. Thanks.
Posted on Feb 02, 2009
SOURCE: Hi,
yes it will support
Posted on Jun 22, 2010
  • 2567 Answers
SOURCE: Does Intel Pentium 4, 2 GHz Processor support 2GB
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
Posted on Sep 05, 2011
  • 26 Answers
SOURCE: my system is pentium 4 and 2.80ghz processor is it support 4 gb of ram
It depends on your motherboard type. Open up the case and look at the number of ram slots and what's written beside them. if ti's DDR2 or ddR3 then it can but normally it's supposed to
Posted on May 16, 2012
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Sep 05, 2011 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
What is the best configuration for intel d945gcnlboard.what is higher capaacity(ram , cpu)of that he can support.
This mainboard uses ddr2 ram and has 2 slots. The max ram that can be run is 4 gigs. Thats 2 2gig sticks.
The CPUs supported are the types lited below.
Intel Pentium 4 Intel 945GC
Intel Pentium D Intel 945GC
Intel Celeron D Intel 945GC
Intel Core 2 Duo Intel 945GC
The socket type is intel socket 775. Almost any of the socket 775 Core 2 Duo processors would work well for you.
Dec 06, 2010 | Intel D945GCNL Motherboard
Hi, i own samsung syncmaster 740n Monitor, from last 5 days, black horizontal lines are appearing on screen.today it is work.black shaded lines are becoming more worst .. what could be the cause, ...
We need to narrown down the causes first by trying this monitor with a good working PC to make sure it is not monitor problem, we do not want to open uip the monitor unless we have to.
Post back what you find, if it is monitor problem then please read below:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Dynet 1gb ram supports
See Intel MB D915GVWB, supported memory link below;
http://www.intel.com/support/motherboards/desktop/d915gvwb/sb/CS-027030.htm
It is best to install memory that Intel suggest. Scroll down to, Vendor Self Tested Memory.
Mike
Aug 10, 2010 | Intel D915GVWB Motherboard
Windows xp crashes frequently after inserting new RAM.
try to use one ram at a time if the 1gb ram does not gve any error thn the 256 mb ram is the culprit and if the opposite happens than 1 gb is culprit yur ram slot also may ve got damaged somehow if the ram is culprit and ti is under warranty get it replced with the same memory clock one
Jan 29, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel Pentium 4 515, 2.93 GHz (JM80547PE0771M) OEM / Unboxed Processor Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
