Question about Canon EOS 1100D Rebel T3 Body Only Digital Camera
Memory Card slot broken?
When you insert the card, it just pops back up...however when you close the battery door on it the camera still reads the card as normal and it still takes/records pictures. What causes this? Can it be fixed? I own multiple dslrs and the Rebel is the primary one I carry round so it saddens me that something could be wrong and hope it can be fixed.
  • 32 Answers
It sounds like the spring-loaded catch that holds the SD card in is missing, broken, or the spring is too weak. If it's reading the card by just closing the battery door, then the card is making a circuit with the camera's internal contacts, but that is far from ideal, and I would not be surprised if that method caused additional damage in the long run. I recommend you bring it to a reputable camera shop, and see what the cost would be for the repair. I suspect it would be a LOT cheaper than breaking the camera or an internal circuit board by trying to kludge a solution. The parts are probably a few bucks, it's the labor cost that you would end up paying for, but better that than breaking the device.
Posted on May 06, 2014
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
JMuskovitz
  • 135 Answers
SOURCE: memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Posted on Mar 05, 2007
SOURCE: problem with canon
Check the CF connector in the camera. One of the pins might be bent...
Posted on Jan 28, 2008
  • 68 Answers
SOURCE: memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Posted on Mar 05, 2008
  • 6 Answers
SOURCE: Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Posted on Apr 02, 2009
Download photos computer
Download photos from any camera is highly unrecommended because that quickly disharges the camera battery. Instead, turn camera off and then open battery door. See picture memory card at camera edge, push in and release to pop up. Then, draw card out of the slot taking care to avoid finger contact with contacts. Close battery door. No insert card into card reader on computer. (Most computers these days have built in reader. USB interface readers can be purchase at low cost.)
If the upload start up dialog does not auto star, then open Computer and double cick open it there. A menu will appear offering wholesalee import you can chose Review Folders in Explorer. Once opened, photos can be handled and stored ot computer like any other file. It is preferable to copy files as opposed to moving them, using camera itself to delete files. Now close Fuji folder and initiate safe removal. When approved, remove memory card and reinsert in camera. Question answered.
Jan 26, 2014 | FUJIFILM FinePix JV100 Digital Camera
Memory card for t3 no longer feels secured in slot
The holder that holds your memory card is broken and needs to be replaced.
Apr 03, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Memory card will not release does contact portion (metal face the back of the camera)?
Yes it does face the back of the camera. Try this: turn the camera over so that the battery/card slot door is facing to the right. When you open the door you should see the batteries first then the slot for your sd card. If you insert the card into the slot from this position the card label should be facing you with the notch in the card facing to the left, this should be how you insert your card. I believe it is on Page 15 of your instruction manual.
If the card is facing with the contacts towards you then it is inserted incorrectly. If you have inserted it correctly then the card is spring loaded so gently push down on the sd card and it should pop up if it doesn't then it is jammed.
If it is jammed you can try to remove it yourself with a pair of needle nose tweezers or you might just have to send it off to canon service center or your local repair/camera shop to remove the card and hope that you have not damaged the camera itself.
Camera Manual:
http://gdlp01.c-wss.com/gds/5/0300003855/04/PSSX130IS_CUG_EN_03.pdf
Sep 21, 2011 | Canon PowerShot SX130 IS Digital Camera
Where do i insert the samsung intensity memory card
Pull off the back cover of your phone by putting your fingernail in the slot on the top back of the phone (right above the camera) and popping the back cover off. Then turn your phone over so you're looking at the back. The memory card goes in the slot to the left of the battery (it should say "MicroSD" on the slot.) It slides in from the side, toward the battery. Once you have the card in, you can pop the rear cover back on.
Jun 04, 2011 | Samsung SCH-U450 Cell Phone
How do I enter my sandisk into my kodak easyshare camera?
Hello
  1. Open the camera memory card door on the side of the camera.
  2. Insert the camera memory card into the slot with the connecting end of the card facing the camera, and the lip on the card facing toward the front of the camera. CAUTION: The camera memory card can only be inserted one way into the camera. Forcing the card in the wrong way may damage your camera.
  3. Push the camera memory card all of the way into the card slot and then close the door. Make sure that no dirt is present when you close the door.
Hope this can help you.
Kind regards
Andrea
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
16G Memory Gets "Memory card Error Please Check Memory Card"
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
Finepix z20fd memory card won't load in slot
Have you ever dropped your camera??
If you have , this is why.
No need to buy a new camera just yet.
Try celotaping it in.
My mom had to do this , after it worked fine!
Dec 26, 2008 | Fuji Finepix Z20fd Digital Camera
Have put in a memory card, But camera keeps displaying memory card full
Try reformatting the card. Use your camera to do it, not a computer.
Dec 14, 2008 | Cameras
Canon EOS 1100D Rebel T3 Body Only Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
