Question about Saniflo E88ac Hand Dryer
How can i correct the problem with the hand dryer running constantly?
    Sergeant:
  • 479 Answers
That would be in the electronic circuit has to be replaced
Posted on Jun 29, 2014
What is more cost effective: hand dryers or paper towels?
We recently switched from paper towels to a hand dryer in my deli. Although the initial cost is definitely more for a hand dryer, I think that it will ultimately end up saving me money that I would be spending later on constantly having to buy more rolls of paper towels.
Apr 24, 2013 | Home
My Kenmore dryer ticks constantly (runs fine)
sounds like the timer running,put your ear to the timer dial to see
Jan 14, 2013 | Kenmore Dryers
Dryer will not keep constant heat
clean your vent that goes out side Thats what does that the hot air dosent go outside but comes back on the temperature control and shuts the heat off. Also if you put wet close it it the lint will be built up behind the fan. You have to lay the dryer down take the back off and fron the bottom on the left side is the vent foller the hoe to the left. there is four 5/16" screw hokling that tub on thake those screws out and raise that unit enough to get you hand to the fan blades and you will find two hands full of linte matted there.
clean that out dryer need good air flow be sure to pull youi vent out the top and clean before each dry.
Apr 21, 2010 | Whirlpool LGB6300 Gas Dryer
After sitting idle for several days, dryer makes a noise at beginning of the cycle when drum stops and starts. Noise no longer occurs after second load dries.
Not sure if your problem has been corrected yet, but the biggest most important task that must be addressed constantly with these machines is lint build up. So I would check your lint trap (change it before or after each load), check your heat exchanger/air inlet on the lower right hand corner of your machine, and then your condensation hose - to make sure that this is clear of blockage. Also, your machine should be in a vented, open area where it gets lots of air. Adequate ventilation is another important feature that affects these machines. So basically, I'd give it a little tune-up/clean-up and see how it runs. Hopefully, this has already worked for you. Good Luck!
Jan 16, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Dryer switch
yeah but its unsafe specially with kids! it could stay running if the door was open and wont stop unless you turn the knob or unplug it. thats if it was bypassed.
Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Dryer stops
It is an electrical problem and unfortunately you will need hands on service to correct the malfunction!
If I were there I could help you!
You will need a hands on tech!
Bless you,
ngafm
Please give me a good rating before you sign off!
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Saniflo E88ac Hand Dryer Logo
35 people viewed this question
Top Saniflo Dryers Experts
Dan Webster
Dan Webster
Are you a Saniflo Dryer Expert? Answer questions, earn points and help others
