Question about Canon EOS 600D Rebel T3i Digital Camera
Memory card slot broken?
When I insert the memory card into the slot it doesn't lock, just pops back up. However when you close the door on it, the camera still reads it as normal and still takes pictures. What causes this? Is it a spring? I have multiple dslrs and the Rebel is my primary that goes everywhere so this saddens me. I hope it can be fixed.
  • 68 Answers
SOURCE: memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Posted on Mar 05, 2008
SOURCE: sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Posted on Sep 27, 2008
SOURCE: Memory Card Locked.... how do I un-lock it?
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Posted on Jan 12, 2009
  • 6 Answers
SOURCE: Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Posted on Apr 02, 2009
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
I can not insert the memory card into my camera
Card slot should be on the right. Make sure you have the correct type of memory card. a SD SDHC or SDXC. They should be 1"x 1.25" or 25mmx32mm. Ensure there is no card in the slot. insert as per pic inside the door with cutoff corner end first and facing up.
once securely in, to remove depress it a little and it should pop back out.
Note if the card does go in but cannot be written to, there may be a write lock slide on the side of the card. up is unlocked.
If you are still stuck then I would stop by a camera shop they should be able to sort you in seconds.
Oct 26, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Show your memory card location
Remove the back cover by holding the phone firmly then slide in the back cover of the handset. You will now see your MicroSD and SIM card slots. Take your SIM card and slide it into the slot provided with the chip facing down. You will also see a small diagram showing you which way to insert the SIM card. Now slide open your MicroSD memory card slot gate, pop your MicroSD memory card into the slot, then close the MicroSD memory card slot gate by sliding it forward then backwards.
Oct 29, 2011 | LG GD510 Cell Phone
Memory card will not release does contact portion (metal face the back of the camera)?
Yes it does face the back of the camera. Try this: turn the camera over so that the battery/card slot door is facing to the right. When you open the door you should see the batteries first then the slot for your sd card. If you insert the card into the slot from this position the card label should be facing you with the notch in the card facing to the left, this should be how you insert your card. I believe it is on Page 15 of your instruction manual.
If the card is facing with the contacts towards you then it is inserted incorrectly. If you have inserted it correctly then the card is spring loaded so gently push down on the sd card and it should pop up if it doesn't then it is jammed.
If it is jammed you can try to remove it yourself with a pair of needle nose tweezers or you might just have to send it off to canon service center or your local repair/camera shop to remove the card and hope that you have not damaged the camera itself.
Camera Manual:
http://gdlp01.c-wss.com/gds/5/0300003855/04/PSSX130IS_CUG_EN_03.pdf
Sep 21, 2011 | Canon PowerShot SX130 IS Digital Camera
How do you put a memory card into the memory card bit?
if it is an external slot ..and not under the back lid...just remove the cover ..and insert the card and pres it in ...it has a click action that locks it in ...and the same when you will want to remove it ...press it with the nail ..inside and after the click will pop out ....If the slot is internal ..see that is has a metal cover that locks in one end and if you pull it out it opens like a lid...insert the card and cover it back ..
Mar 16, 2011 | LG GT540 Cell Phone
How do I enter my sandisk into my kodak easyshare camera?
Hello
  1. Open the camera memory card door on the side of the camera.
  2. Insert the camera memory card into the slot with the connecting end of the card facing the camera, and the lip on the card facing toward the front of the camera. CAUTION: The camera memory card can only be inserted one way into the camera. Forcing the card in the wrong way may damage your camera.
  3. Push the camera memory card all of the way into the card slot and then close the door. Make sure that no dirt is present when you close the door.
Hope this can help you.
Kind regards
Andrea
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
Installing the 1gb card
Remove the sheel backside of your phone
remove the battery
now you see your sim-card
you place the sd-card just at the right side of the sim-card
lift the mediacard holder
insert the sd-card into the slot in the mediacard holder so that the metal connectors on the card will align with the metal connectors on your phone when the media card holder door is closed
close th media card holder door and slide the media card door away from its hinges to lock it
put back the battery and shell and you done!
If you still dont know, here is an demostrator how your phone works
http://demos.blackberry.com/8310/na/us/gen/
Good luck
Dec 07, 2008 | SanDisk 2GB microSD Memory Card
My vivitarN1659 will not reconize a1gb memory card and either states that the memory is full or that the memory is locked
There should be a tiny lever on the side of the memory card. Unlock the card by pushing the lever up. If it still says memory card is full, take out the battery and push the memory card further into the slot. It should not move while it is in the slot. If it "floats" when you close the battery door, it is not down far enough into the slot. Return the battery and close the door.
Oct 05, 2008 | Cameras
Canon EOS 600D Rebel T3i Digital Camera Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
