Question about HP LaserJet 1020 Printer
12a cartridge gives 4 horizontal line - HP LaserJet 1020 Printer
    Master:
  • 409 Answers
This sort if thing is acually caused by a mark on the drum. Check to see if it comes out on this printer and see if it is scratched. Drums are usually a user replaceable part that can be purchased from HP or other HP stockist
Posted on May 06, 2014
My hp1010 printer gives horizontal white line or bars between character.
Try a different cartridge, blank horizontal would point towards a possible drum issue. Does the defect repeat down the page?
Sep 12, 2016 | HP LaserJet 1010 Printer
My 12A cartridge after refilling,giving wet type print
If you are getting smearing then likely the drum is dragging. If you simply added more toner without emptying the waste bin that would be the reason.
Aug 17, 2015 | HP 12A Toner (Q2612A) Printer
Solve horizontal line in cartage 12A
Horisontal line: I assume you mean a line across the paper movement direction. Please, inspect if the line is repeating on exact distance from one to the other. Measure the distance, divide by Pi (3.14) and you'll get the diameter of the faulty roller. Also, please, make a half print test page (open the cover in the middle of the printing process). Inspect if the line is appearing before the fusing unit or after it.
Try printing with different cartridge, just to be sure the cartrige is causing the problem.
Primary charge roller and its bearrings can be dirty and not charging enough the drum, causing black lines
Weared stripe on the OPC drum caused by friction with jammed paper improperly pulled out can also be the root of the problem. Faulty laser-scanner unit can also write black lines randomly. Weared teflon sleeve on the fusing unit can accumulate toner and print repetitive defects.
Oct 09, 2014 | HP LaserJet 1020 Printer
Horizontal line
change wiper blade (drum cleaning blade )
Mar 29, 2014 | HP 12A Black Laser Toner Cartridge...
HP 1010 12-A CARTRIDGE...
Hi
Replace the ink cartridge with another
Jan 14, 2014 | HP 12A Black Laser Toner Cartridge...
Horizontal lines appear every 4 inches on each
User manual page 6.17 says:
Horizontal streaks indicate improperly installed or defective toner cartridge. Try re-installing the cartridge.
http://downloadcenter.samsung.com/content/UM/200607/20060712143739406_ML-1710_English.pdf
Nov 28, 2009 | Samsung ML 1710 Laser Printer
HP 4 PLUS HORIZONTAL LINE EVERY 4TH PAGE
Based on what you described the problem may be with your toner cartridge. The green photosensitve drum has become faulty somehow. I'd suggest trying another toner cartridge, it's the easiest way to determine what the problem is.
Another part that could be at fault is the scanner. It "etches' the image to the drum inside the cartridge, so if the scanner is bad it can make it look as if the toner cartridge is bad.
Jun 29, 2009 | HP LaserJet 4 plus Printer
How to refill, hp laserjet 12A cartridge, manually?
You will regret it if you attempt this. Although this is a small cartridge, it is difficult to remanufacture correctly.
Mar 09, 2009 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
