Question about Philips Audio Players & Recorders
"why wouldn't my philips pocket memo 9730 charge"
  • 61 Answers
SOURCE: On the Philips Pocket Memo 381 how do I get the
When switch is on the machine will work as before but should stop about two seconds after you stop speaking. Note, this is really a noise activation switch and a high background noise will keep it going. It has been common practice to disable this feature as it is often been the cause of misunderstanding by users.
Posted on Apr 25, 2010
  • 61 Answers
SOURCE: I have an old Philips Professional Pocket Memo 398
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
  • 61 Answers
SOURCE: Philips Pocket Memo 398 dictation machine - spindles not turning
Most likely cause here is a broken drive belt. This machine is at least ten years old. The belts for the latest model (381) will fit, but it's a tricky job to fit.
Posted on May 17, 2010
  • 61 Answers
SOURCE: can't get a playback of dictation
Download it from www.dictation.philips.com.
  • 61 Answers
SOURCE: I have a Philips pocket memo 381 that lets out a
This is the end-of-tape signal. Try turning the cassette over. If this does'nt work then there is no tape drive due to the belt coming loose or breaking.
Posted on May 20, 2010
Philips pocket memo LFH 9730
Hello I don't recognize that model may be you try to say Philips Digital Pocket Memo LFH9370.
Your unit charges two ways via power supply direct on the portable or via docking station, make sure you have the proper rechargeable batteries you must have the LFH9154 if you don't have this batteries you can buy them on the next link http://www.tvps.com/Products/Philips-LFH9154-AAA-NiMH-Rechargeable-Batteries---New-9154__PH-LFH9154.aspx
May 06, 2014 | Philips Audio Players & Recorders
Driver for Philips Pocket Memo 9300
Hi, fortunatley I found the old setup/installation-disk! Download and enjoy!!! Gunter
https://dl.dropboxusercontent.com/u/6605634/philipsLFH9300.zip
Nov 26, 2011 | Philips Pocket Memo 9300 Handheld Digital...
Cannot run philips LFH9398 pocket memo on my mac
the philips models are not MAC compatible. However, they normally show up as a folder and you can copy files.
Apr 29, 2011 | Philips Pocket Memo 9360 Handheld Digital...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
Where is the on/off switch for teh Philips 9350 pocket memo
Move teh 4-position switch to the stop position and push back the movable center part of the cap.This locks the 4-position switch and the device switches off.
MANUAL
Sep 29, 2010 | Philips Pocket Memo LFH9350 Digital Voice...
I have a Philips pocket memo 381 that lets out a loud bleep when trying to record on it. Batteries have been changed twice this makes no difference.
May 05, 2010 | Philips Pocket Memo 381 Handheld Cassette...
Mar 25, 2009 | Philips Audio Players & Recorders
Phillips 281 pocket memo
Go to www.dicatation.philips.com and download manual for model 381. It works exactly the same.
Mar 02, 2009 | Philips Pocket Memo 281 Handheld Cassette...
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
