Question about Iomega eGo 1TB USB 3.0 Portable - Ruby Red USB 2.0 Hard Drive
Why does my 500gb iomega ego encrypt plus shows only 15mb of total memory.
bob_computer
  • 3153 Answers
SOURCE: Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
Posted on Nov 20, 2009
  • 51 Answers
SOURCE: I'm trying to format my Iomega 500gb ego so that I
you have to use an other HDD having OS on it... and attach other HDD and format it ..it will work!
Posted on Mar 18, 2010
  • 10406 Answers
SOURCE: I have a iomega eGo
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
Posted on Nov 04, 2010
  • 74 Answers
SOURCE: Iomega eGo 1TB USB 3.0 Portable portable harddisk
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Posted on Dec 24, 2010
  • 74 Answers
SOURCE: I just purchased an iomega
You will need to format the drive to work with you Mac.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon.
NOTE: For devices with 2 or more hard drives, please review the configuration settings to determine which volume type works best for you.
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
I forgot the password of my ego iomega encrypt plus it is also write protected
This WEB site may remove the HD password.
A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Jul 21, 2012 | Iomega eGo Portable Hard drive 500 GB ...
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I can see my folders but when i go to access them they don't have any content?
Hello Quincy964,
Ensure first that the computer where your Omega 500GB eGo Helium Portable plug-in, is an virus free PC. Your problem is mainly cause by an virus. You can unhidden it by 3 different methods;
Method 1:
By using "ireset" software
Here is the link : ireset
Just download the link,open the software then after just drag and drop the whole folder in the software then click reset. And all the files in your folder will automatically unhidden.
Method 2:
By using Linux Operating System
Just plug your Iomega 500GB eGo Helium Portable into an Linux Operating System, and automatically you can see or browse all the files in your hard drive.
Method 3:
By using Hiren's Boot CD
Just download and Hirens Boot CD (download here)
Download the file in the link, then after an successful donwload extract the files in the zip folder then burn it in Nero DVD Burner (Choose in the Nero DVD burner >burn images files) then after burning it. Restart your computer (makes sure that the Hirens Boot CD is inserted in your Optical Drive) boot it up in your Optical Drive ( F12 or F11 depending on the motherboard). After booting in the CD, Hirens meu will show then choose Mini XP. It will boot in an Windows XP like GUI, then plug-in your Iomega 500GB eGo Helium Portable into the PC then click into My Computer in the desktop, then open your folder and you will see all the files in there.
I hope it will solve your problem
Thanks for using Fixya..;-)
Aug 15, 2011 | Iomega 500GB eGo Helium Portable 500 GB...
I forgot the password of my ego iomega encrypt plus and the admin password is also locked ... how do I access the disk ...I am unable to even format it
Last time, when my Samsung mobile phone was locked by password, I also forgot the password and tried to disable the password protection functions by using the ways searched over the internet.
Maybe it may also work for your iOMega mobile phone.
Read more here:
How to disable android phone password protection
Aug 02, 2011 | Iomega eGo Portable Hard drive 500 GB ...
L just bought iomega ego 750gb - portable hardrive. They clearly told me in PC World that l can password protect my files with the iomega ego. l cant seem to setup the password. l carry sensitive files...
You will want to encrypt the hard drive. One of the most popular programs is PGP, it is free and open source. Once this is done, you will will have to enter a password when ever you try to access that drive.
Mar 04, 2011 | Computers & Internet
Hello support First of all I'm not that kind of men who keep thier things I threw the user guide that comes with the hard disck as soon as I bought it but when I wanted to open my hard disck it...
Your hard drive encrypts all the data put on it, so you need a password to access it. If you haven't changed anything, the default password should be just the word "password" I would recommend changing that as soon as you get into the drive. There should be a very obvious option in the program once you enter the password for the first time.
Feb 26, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Iomega eGo 1TB USB 3.0 Portable - Ruby Red USB 2.0 Hard Drive Logo
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
