Question about Dell Inspiron 531s Desktop Computer
What do I do when scannow and chkdsk /f can't fix corrupted files?
I tried running "sfc /scannow" and "chkdsk /f" and both say that it found corrupted files but was unable to fix them. What can I do to fix them? My system is running Windows Vista Home Premium
  • Dell Master
  • 1,087 Answers
Windows failed to load because the system registry file is corrupt
1st way:
Run CMD as administrator. Run CMD as administrator. Type chkdsk /f c: or d: or e: (where U'r windows installed)
2nd way:
Insert your DVD windows installer. Run CMD as administrator. Type sfc /scannow and follow the instruction
Sep 05, 2014 | Computers & Internet
Memory violation c0000005
Usually this is either bad RAM or a corrupted file. Check the ram by removing all but one stick and testing them one at a time. Chances are you will find the bad one pretty quick.
If it's a corrupted file do two things. Run SFC /Scannow from an administrative command prompt AND run chkdsk /f t find any bad spots on the drive.
If you find bad spots and corrupted files, back up your data and prepare to get a new hard drive.
good luck
Jun 11, 2014 | Microsoft Windows Vista Ultimate Edition
Oop's system error has ocurred restarting..,
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. also download the registry cleaned cc cleaner
http://download.cnet.com/ccleaner/
You can also run a free registry scan using utilities from http://re7.info http://www.download3000.com/showarticles-182-0-date.html System Utilities. http://www.download3000.com/showarticles-178-0-date.html Optimisers and Diagnostics.
Hope this helps.
Dec 23, 2012 | Computers & Internet
Missing hss.dll driver file
You could run the chkdsk utility. Cick start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility Cick start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors then select check now start should schedule this task when restart it will only schedule on restart if its the Primary hard drive with an operating system on it do not do anything while the chkdsk utility is in progress any input may damage your operating system and your computer. Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps: Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow. Type the following command, and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 13, 2012 | AnchorFree Expat Shield
Windows updates doesn't work
click start type cmd press enter then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
hope this helps
Sep 27, 2012 | Microsoft Windows 7 Ultimate Upgrade OEM...
Hanging on booting after memory count
Sounds like the boot files might be corrupt. Click Start/All Programs/Accessories then look for the Command Prompt. If you don't see CMD, click RUN and type cmd in the box and press enter. A black window will open allowing you to type in commands. Try the following command by typing: sfc /scannow (it will run a while and when it finishes try rebooting). If sfc fails to fix the problem try this command: chkdsk /r
Chkdsk will run an hour or more so be patient and let it do it's thing. You'll even notice that the percentage of completion will go from high to a lower percentage in the process. That's ok, just be patient and let it run until completion.
Mar 09, 2012 | HP dc7600 Convertible Minitower PC Desktop
How do I restore XP rundll32.exe?
I've used SFC to repair Windows 2000/2003 servers in the past, it debuted in Windows 2000 and it fixes system dlls. Start > Run > type 'cmd' and 'sfc /scannow'. You will have to insert a Windows XP SP2 cd for it to work (or mount and ISO of XP with a tool like alcohol 120).
If the %systemroot%\system32\dllcache folder becomes corrupt or unusable, use sfc /scannow, sfc /scanonce, or sfc /scanboot to repair the contents of the Dllcache directory.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/system_file_checker.mspx?mfr=true
Jan 12, 2012 | Toshiba Satellite P105-S9337 Notebook
My windows movie maker was corrupted... how can i fix this problem?
First try running (start-run) "sfc \scannow" and let us know if that fixes it, SFC stands for System File Checker and you can ask it to fix problems that it finds although I think it does that automatically anyway. Hopefully its just a problem with a system file and sfc will fix it for you, otherwise check back with us and we try again :)
Oct 31, 2010 | Microsoft Windows XP Professional SP2
Ive an emachine730 and windows installer is corrupt will using my
If your running XP and you have your cd handy use can use SFC
(system file checker) to repair any corrupt files.
Open Run and type SFC /SCANNOW
When it completes restart your system and download the windows 3.1 installer as SFC will replace the corrupt one with the orginal version.
Mar 23, 2009 | E-Machines eMachines Desktop PC
Dell Inspiron 531s Desktop Computer   Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
