Kenmore 23812100 no drain or spin
  • 1937 Answers
SOURCE: Kenmore Washer Model#23812100 It wont speen adn
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site for your washer may have a section on the gearcase. Check in that section for a Neutral Drain repair kit.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
Posted on Oct 31, 2009
Testimonial: "It Was the "LId Switch ", this particulat top loader model , will agitate with the lid open however it will not speen and/or drain the water out...."
  • 1937 Answers
SOURCE: No Spin Cycle in Kenmore 80 Series Top Loading Washer
First, see the Sears parts site for your washer: Following is the Sears site for Whirlpool (110.) models with your model number.
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Following is a description of how to release the console for access to the pins.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Jan 18, 2010
  • 161 Answers
SOURCE: model no. 23812100
you have a bad lid switch-it thinks the lid is up
Posted on Apr 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: 80 series mod#23812100 washer after wash
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
  • 1937 Answers
SOURCE: I have a kenmore 23812100
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023812100/0582/0153200?pathTaken=
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it works, the Lid Switch is a relatively inexpensive part. See the Sears parts list with prices.
Posted on Jan 04, 2011
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
110 kenmore loader top 23812100
If it is not the lid switch then it is the motor switch. Here is that part to order.
Oct 10, 2013 | Kenmore 22422 Top Load Washer
Hi Fixya, I have a Kenmore top load washer Model# 23812100. I have spin issues. I replaced the lid switch and the coupler and the spin cycle is now spinning slow and seems like it wants to spin but...
Make sure that the motor is spinning with correct TORQUE. If this seems good then the washer must SPIN inthe cycle. A loss of RPM can then be due to the clutch slippage as it fails to engage fully to the motor. Best is to check this assmebly and change the spare requied.
check for tips on the link below;
http://www.espares.co.uk/advice/washing-machines/a/7
Jul 19, 2011 | Kenmore Washing Machines
Kenmore 80 Series 23812100 won't spin or drain. I can hear the motor make a buzz, but it never initiates. What is causing this? Thanks. :)
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | Kenmore 23812 Top Load Washer
I have a kenmore 23812100 top load washer that fills up, but stops prior to the draining stage for spin cycle. It just stops after the soaking cycle when its supposed to drain out to rinse. What could be...
Jan 04, 2011 | Washing Machines
Model no. 23812100
Apr 16, 2010 | Washing Machines
How do you replace a clutch in a kenmore 80 series mod#23812100
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Please see the following :
You don't have to remove the agitators to remove the transmission and clutch.
Oct 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washer will not spin properly on a Kenmore 110 23812100
your pump is partially clogged or your drain hose is kinked
Dec 09, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
