I turned on my humidifer for the first time this year. It runs, but isn't picking up any water. It worked fine last summer. Any suggestions? Also, Is this model under any type of warranty yet?
Comments:
Jun 23, 2009
- It is clean as a whistle. When I opened it up, the termostat was corroded and rusted off. Are parts available online?
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!...
(More)
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit! I've checked for cracks in the bucket but its fine and collects water too but the unit still leaks:( Everything else is fine with the unit but this. What is going on here? It worked without any leaks for a couple of years and now this! And how do I fix this problem?
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the...
(More)
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the reservoir well stays dry.
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no...
(More)
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no water is accumulating in the tank. I took the back off and no ice is accumulating
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last...
(More)
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last month it shut off and now won't power up. When plugged in, the control panel will not even light up. Seems totally dead. Do you have any adice? Is there a fuse on the unit? Please advise.
