Question about Lanier Office Equipment & Supplies
We had a power outage and now my lanier 6523 copier won't copy. It says ready but won't recognize that I hit the numbers. Is there a reset or something?
    Novelist:
  • 158 Answers
Try turning it off, then unplug it from the wall, wait 30 seconds, and plug back in, then turn it on and try to operate.
Posted on Jun 22, 2009
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
While using Bluetooth I hit forget this device. I need to use the device now but it won't recognize it. How do I reset the Bluetooth?
Easy; Go to settings and tell the device to scan for devices. Obviously make sure the device you want to use is turned on first and all going well, your phone will tell you your ready to use that pareticular bluetooth device. Good Luck. George
Mar 30, 2013 | Apple iPhone 3G
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
How do you enlarge copies using a Lanier LD015spf
The option for enlarging copies on any printer are usually found under the "properties", or, "preference" tab/button. There should be sub-tab that says "scaling" that is defaulted at 100 percent. Increasing that number enlarges the copy.
Hope this helps. :)
Oct 02, 2010 | Lanier Office Equipment & Supplies
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Nov 16, 2008 | Sharp AL-1551 Laser Printer
Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
Nov 04, 2008 | Office Equipment & Supplies
69 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
