Question about Troy Bilt 175HP Manual 42" Riding Mower
How much oil is used in a 17.5 hp B&S engine ?
  • Troy Master
  • 2,478 Answers
About 4 pints
Posted on May 06, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
About 1 and 3/4 of a quart. First add a full quart check the level. Then slowly top off with the second bottle. Keep the rest for the season as you slowly burn it off.
Posted on May 10, 2014
My toro 17-44HXL model with a B/S 17HP engine stalls when trying to drive horizontally on a slope. It stalls when sloped either right or left side sloping.
The float in the carburetor might not be floating at the right height due to the slope. It's also possible fuel might not be reaching the carburetor as it hates to flow uphill. It's unlikely it has a fuel pump. Hopefully, it has an oil pump (and associated oil filter). Engines without oil pumps don't like inclines very well.
Jun 18, 2016 | Toro Garden
21 HP briggs & stratton engine burns 6oz of oil & the spark plug is black with oil & carbon there is no smoke from the exhaust
Check in your user manual and see what weight of oil you should use in your engine. If the weight of oil is too low it will let it burn pass the rings and the valves. I use Briggs & Stratton 30 SAE oil in all my engines. If the engine is old you may have to do a valve job or clean the valves and head which do carbon up and need to be cleaned from time to time.
Aug 22, 2011 | Garden
Where is the oil filter on a 17 HP Craftsman briggs & Straten engine and what grade of oil do I need
It may not have a filter, but if it does it would be a small spin on type on the left side of the engine about 4 inches in diameter. Use SAE 30 in that engine. It takes about 48 ounces of oil. Sears sells 48 oz bottles or you can use oil from your favorite auto parts store. Just don't over fill or it will smoke. Verify level with dip stick screwed in.
Oct 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I had Craftsman lawn tractor given to me. It's about 8 years old and has a 17 hp Briggs & Stratton engine. I found oil in the carb, and I think it's ceased, because I can't turn the flywheel. Anything...
is there oil in cylinder head? if so engine could have been tipped over wrong way causing oil to run into carby and cyl/head....drain oil from engine and cyl/head and see if you can turn over by hand
Aug 08, 2010 | Craftsman Garden
HOW MANY CFM DOES THIS COMPRESSER DELIVER AT 100 PSI
If this is the compressor the amount is 16.2 at 100PSI. PLease see attached link:
http://www.toolfetch.com/p-d55275.shtml
I hope this may have helped,
Tom
Oct 16, 2009 | Dewalt D55275 8 Hp Gas - Powered 17 -...
Valve adjustment for 17 & 21 hp engines. are
Overhead Valve Engines with solid lifters need a valve adjustment as part of routine maintenance. This is normal wear for every brand using solid lifters.
Hope this helps.
Oct 04, 2009 | Garden
Troy Bilt 175HP Manual 42" Riding Mower Logo
55 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
