Question about Whirlpool Dryers
Dryer will not start. Power light is on. No coins are stuck in drum liner. No blockage. Recent repair replaced mother board at a cost of $500.00. The same repairman rep
  • Jim Platt
    Jim Platt May 06, 2014
    Repair company replaced a fuse after the new mother board did not work could that fuse have blown?
    Novelist:
  • 150 Answers
Without a complete model number it's hard to say which direction to go. You might need a door switch, some door switches with an interior drum light will be a 3 wire switch allowing the interior light to come on but not the dryer start when the door is closed. Some dryers had a start relay mounted inside the control panel, which is controlled by the main board, failure of these relays can cause a no-op situation. Pleazer Appliance...
Posted on May 20, 2014
  • 38 Answers
SOURCE: coins stuck in tumblers on my Nebtune Dryer
Try calling a local repair man they could probably take it apart and take it out.
Posted on Dec 22, 2007
  • 90 Answers
SOURCE: Kenmore 11060052991 No start
have you checked the thermal fuse, if bad replace and clean vent.
Posted on Jan 05, 2008
Master_Tech
  • 770 Answers
SOURCE: SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Posted on Feb 16, 2008
dniro592006
  • 121 Answers
SOURCE: LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Posted on Apr 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Push start button but won't start after belt replaced
Did he remember to plug in the door switch on re-assembly?
Posted on Jun 12, 2009
Lower part Neptune dryer wont turn on
I could be all wet with this but have you check the switch on the door see if it's stuck----also the answers given before are good replies----do you have a schematic?----you've replaced the mother board so depending that's not faulty it should work or you've eliminate one issue---what ever sequence follows the events that start the dryer----by more info--- is the drum turning??----is it turning and your getting no heat----another issue which may or may not be the case is polarity via house wiring----have you had any recent issues with your wiring----wire changing and or service entrance---utility pole replacement----storms---lightning---these are things that can drive electronics nuts with out knowing it---this is all I can think of at the moment---get back to me with more info if you can
Feb 21, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Noise from machine
1.check if the bra wire is poking out of one of the drums.Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2.clear the water pump from obstractions like coins or small objects there might be some coins stuck in it that are causing discomfort.
if all the above fails try to run the motor alone without the belt if you still hear the noise its the motor that has a problem
Oct 27, 2012 | Hotpoint Aquarius WD640 Front Load...
GE Gas Dryer DBSR453GB1WW began squeaking during the most recent drying cycle. We should we try to repair ourselves or get a repair tech?
The squeaking noise is most likely emitting from the drum bearing (key#543). In order to access and replace the drum bearing will require removing the drum. The drum bearing/sleeve is part# WE1M462. I added the instructions on how to remove the drum in the images below. NOTE: Disconnect the power cord from the power source before servicing the dryer.
Jan 13, 2011 | GE DBSR453GBWW Gas Dryer
My clothes are sopping wet when the wash has finished and there is water at the bottom of the drum. I can sort it by taking clothes out, bailing out the water and then re-spinning the clothes twice to get...
Sounds like a blocked outlet pipe. It may be possible that a small item of clothing i.e. sock or baby item may be stuck between the drums and occasionally moves over the outlet from the drum causing the blockage, hence only happens once in a blue moon. To see if you can see if there is something between the drums use a flashlight to help you look through the holes in the inner drum to see if there's a stray sock or something that can be moving around between the drums and covering the outlet. If there is then you will have to remove the outlet pipe from the bottom of the drum to try and remove the item that is causing the blockage, check all the way around the drum as it may be stuck to the inner drum at the time. If no item is found between drums then the blockage may be in the outlet pipes (both sides of the pump) or in the pump. Check these also as it may even be a small button or coin creating a blockage if it is moving around.
Feb 25, 2010 | Hotpoint Aquarius WD63 Front Load...
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Throws the drive belt. Drum appears loose.
Sounds like drum bearings?? not for the faint hearted! could cost around 100 to get engineer to repair.
Aug 02, 2009 | Ariston Technologies Ariston AWD12 Front...
Coin Stuck In My Dryer
well, i can get into the machine, not aproblem.. is the coin perhaps trapped inside one or more of the innerr drum viens perhaps??? anyway, ifyou removet he2 screws securing the door, and the 2 screws opposite the hinge, the front "u" shaped front panel will tilt off fowards.. from there theres a few 5/16 screws holding the main top assy to the froma of machine, you can remove them and tilt the top back, giving you acess to the outer drum assembly( and you can removethe drum viens and retreive te hoffending "coins" in htat fasion.. hope this helps.. TURN OFF POWER TO UNIT<< LIVE WIRES!!!!!!!
Feb 12, 2009 | Maytag LSE7806A Top Load Stacked...
Oct 21, 2008 | LG DLE7177 Dryer
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
