During what phase of meiosis do non sister chromatids cross over
What is the word for cell division?
Both mitosis and meiosis, as already mentioned (two different types) could be used. More correctly, I'd say Cytokinesis, the process after mitosis, where the cell is actually split. I guess that would be something like the second telophase for meiosis.
https://www.quora.com/What-is-another-name-for-cell-division
https://answers.yahoo.com/question/index?qid=20100430095454AAX0PqJ
Binary fission
Jan 24, 2017 | The Office Equipment & Supplies
HELP ME WITH THESE CODES!!
What engine ? 3.8 or 5.3 L
DTC P0128: Engine Coolant Temperature (ECT) Below Thermostat Regulations Temperature
DTC P0411 : Secondary Air Injection (AIR) System Incorrect Air Flow Detected
DTC P2440 : Secondary Air Injection (AIR) Valve Stuck Open
DTC P2431 : Secondary Air Injection (AIR) System Pressure Sensor Performance
Circuit/System Description
The secondary air injection (AIR) system aids in the reduction of hydrocarbon emissions during a cold start. The system forces fresh filtered air into the exhaust stream in order to accelerate the catalyst operation. An electric air pump, the secondary AIR injection pump, provides filtered air on demand to the AIR control solenoid valve/pressure sensor assembly. The AIR control solenoid valve/pressure sensor assembly controls the flow of air from the AIR pump to the exhaust manifold. The AIR solenoid valve relay supplies the current needed to operate the AIR solenoid valve/pressure sensor assembly. A pressure sensor is used to monitor the air flow from the AIR pump. The powertrain control module (PCM) supplies the internal pressure sensor with a 5-volt reference, an electrical ground, and a signal circuit.
The AIR diagnostic uses 3 phases to test the AIR system:
DTCs P0411 and P2430 run during Phase 1
DTCs P2430 and P2440 run during Phase 2
DTC P2444 runs during Phase 3
During phase 1, both the AIR pump and the solenoid valve are activated. Normal secondary air function occurs. Expected system pressure is 8-10 kPa above BARO.
During phase 2, only the AIR pump is activated. The solenoid valve is closed. Pressure sensor performance and solenoid valve deactivation are tested. Expected system pressure is 15-20 kPa above BARO.
During phase 3, neither the AIR pump nor the solenoid valve is activated. AIR pump deactivation is tested. Expected system pressure equals BARO.
In all 3 phases, testing is accomplished by comparing the measured pressure against the expected pressure. The PCM can detect faults in the AIR pump, AIR solenoid valve/pressure sensor assembly, and the exhaust check valve. The pressure sensor can also detect leaks and restrictions in the secondary AIR system plumbing.
Chevrolet Malibu P2432 Secondary Air Injection System
Jan 29, 2018 | 2006 Pontiac Grand Prix
Comm error 442
From the HP website:
420 V.34 negotiations have failed from the originating machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution:
Reattempt the fax reception at a different time when telephone line conditions have improved. 421 V.34 negotiations have failed from the originating machine during phase 3. Phase 3 occurs after V.8, before phase4, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution:
Reattempt the fax reception at a different time when telephone line conditions have improved. 422 V.34 negotiations have failed from the answering machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged.
Solution:
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
Solution: Reattempt the fax reception at a different time when telephone line conditions have improved.
Solution: 1. Reattempt the fax reception at a different time when telephone line conditions have improved.
Jul 25, 2011 | HP LaserJet 3050 All-In-One Printer
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
How to fix P2430 code on a 2006 Pontiac Grand Prix
P2430 Secondary Air Injection System Air Flow/Pressure Sensor Circuit,
During phase 2, only the AIR pump is activated. The solenoid valve is closed, this is p2430 and p2440. -The AIR system pressure sensor is stuck. good-day !!
Jul 15, 2011 | 2006 Pontiac Grand Prix
Reason of the three-phase UPS system stoped by cross current
The APC 1400 is a single phase device...I'm not sure what it is that transpired can you explain a little more in detail please
May 19, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
How to reset my factory setting in my n95 phone? i forgot my pwd.
Hi
Be warned: backup any important data before attempting this with your phone
Press Call(green button) + 3 + * simultaneously during the bootup(startup) phase untill you see the first screen , forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Mar 30, 2009 | Nokia N70 Cellular Phone
My iPod nano chromatid is not connecting with iTunes???
We have to try connecting thr ipod to computer and charge it for atleast 4 to 8 hrs in the begining.. Then install the latest version of itunes form www.apple.com/download/itunes
After that connect the ipod to ur computer USB port (Desktop:connect at the rear USB port) Then set it up.
If found any issue jus reply
Jan 17, 2009 | Apple iPod nano 3rd Generation
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
