Question about Kyocera Office Equipment & Supplies
How to fix error code 502 on HP 3530 printer - Kyocera Office Equipment & Supplies
5 Suggested Answers
SOURCE: printer failure when trying to print, error message 502
Try cleaning the slider bar  upon which the ink cartridge slides abck and forth -- NOT THE TAPE- the slider bar assembly it self .. It worked for me .
Posted on Dec 02, 2008
rockfixya
  • 679 Answers
SOURCE: printer error 502
Shut down the printer, check whether the printer has peripheral devices such as a stabilizing power supply, and disconnect them.After five minutes, restart the printer to see whether the fault corrects itself. If the fault persists, the heating component may be faulty and the printer will need to be repaired.
Thanks for using FixYa.
Posted on Feb 03, 2009
  • 19 Answers
SOURCE: panasonic DP 3530 printer keeps saying Machine error E03-40
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
Posted on Jul 19, 2009
pineworks
  • 4041 Answers
SOURCE: It keeps saying hardware error 502. Help
Hi
It is the rod that the cartridges travel on. Just wipe this rod with a Kleenex and the
Other thing you could try is to lubricate the bar that the carriage
All The Best: Pineworks
Posted on Jan 31, 2010
502 error code on hp pavilion dv4 1280us
Remove the bottom cover of the laptop. The CMOS battery is a disc 3.2 volt li-on battery. replace it with the same voltage and size battery.
Mar 26, 2014 | HP Pavilion Computers & Internet
3530 error code 110-0001
how to solve the problem code E000000-0001
Jun 29, 2013 | Canon IMAGERUNNER 3530 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Wont print code 502
Hi there
I have had alook around for you and I found your error 502.
Better than I tell you how to fix this just go to the website link and it will show you what you need to do to fix this.
http://en.community.dell.com/forums/t/19262396.aspx?c=us&l=en&cs=&s=gen
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
Feb 27, 2010 | Dell A940 All-In-One InkJet Printer
E000002-0102
this is a fixing unit malfunction code you need a new fixing unit
Aug 03, 2009 | Canon IMAGERUNNER 3530 Copier
System error C4200 on kyocera 3530 printer
try doing a reset... with the copy screen on press 10871087 then when screen changes enter 906 then press enter then start then enter... if that fixes it run to the store and get you a nice expensive surge protector... if that does not fix it then your main board is fried...
Jun 05, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Panasonic DP 3530 printer keeps saying Machine error E03-40
Apr 13, 2009 | Panasonic Workio DP-3530 Copier
Printer error 502
Jan 26, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
23 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
