Question about GE Electric Smooth Top Range
What dose it mean when dispaly says bad cord
When I plug in and turn the breaker on the display says bad cords
  • 957 Answers
You may want to look at the cord where it connects to the range to see if it is loose or burnt. Check the whole cord to see if there are any breaks in it anywhere. The cords are not real costly so you can replace it yourself.
Posted on May 06, 2014
My jayco Setec is tripping house circuit breaker when van and shed are touched at same time
Well Circuit Breaker or GFCI? a couple of possible issues,
If you are on a GFCI then you have a short somewhere.
1. check if anything plugs into the cord will it trip,
bad plug cord either end.
2. If only with the Jayco & when you turn something on?
A. Short in the Jayco somewhere,
B. Line Drop (too small of gauge of Extension Cord)
Hope I helped,
Mike
Mar 11, 2018 | Electrical Supplies
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
Skill saw table saw model 3400.Bypassed on off switch still no power?Does motor have a breaker on inside?
I have the same saw.
Sorry but this question has to be asked, is the AC (Alternating Current) outlet working/ an live outlet? Had to ask.
If outlet is good move on to the next steps.
Take an ohm meter / continuity meter.
With the AC power cord unplugged from the AC wall outlet.
Place the two test leads from the meter onto the plug prongs .
With the switched closed/ON, you should get zero ohms (or very low, close to zero/ continuity).
In your case you probably will not have any continuity because it doesn't turn on.
Now comes the fun part trying to find the problem/ open connection.
Lots of possibilities.
  1. The AC cord could be bad at the plug end.
  2. The AC cord could be bad at the point entering the table saw.
  3. The motor could be bad.
  4. The brushes in the motor could be bad.
  5. The field winding in the motor could be open/bad.
The plan is to ohm/continuity check the path of the power going to the motor, (both sides of wiring).
While meter leads are on the AC plug end, wiggle the strain relief ends. You have an intermittent connection.
TROUBLE: SAW WILL NOT START
PROBLEM 1. Power cord is not plugged in.
2. Fuse or circuit breaker tripped.
3. Cord damaged.
4. Burned out switch.
REMEDY 1. Plug saw in.
2. Replace fuse or reset tripped circuit breaker.
3. Have cord replaced by an Authorized Skil Service Center or Service Station.
4. Have switch replaced by an Authorized Skil Service Center or Service Station.
May 25, 2016 | Saws
Orbit station manual
if timer is plug-in, check outlet for power
if timer is hardwired, then push breaker fully off then fully on
Aug 24, 2014 | Hardware & Accessories
Why won't the breaker on the power cord of my intex krystal clear saltwater system reset?
Defective breaker or shorting pump. Disconnect the appliance from the cord. Does it reset? yes means your appliance is bad. No means that the breaker is bad. A cord with a breaker is not the way to safely operate the pump. You should use a ground fault protected outlet or a cord with a GFCI built in. Either way if the safety device continues to trip, you have a problem with appliance.
Aug 03, 2014 | Intex Krystal Clear Saltwater System Pool...
Why dose my guitar amp make a high pitch sound when i turn it on
If you have an instrument plugged into the amp, then you need to turn down the volume of the amp before turning on the amp. Otherwise you risk permanent damage to your speaker. Also, the instrument cord may be defective. The hot and ground wires may be shorted together. You need an ohm meter to test your cord. With the cord unplugged and detached, put the positive (red) lead of the ohm meter on the tip of the plug and the negative (black) lead on the sleeve of the plug. You should not have any reading at all. If you get a reading then you have a bad cord with a short.
Aug 01, 2010 | Marshall 15 Watt Guitar Amp
I have a 15 amp air conditioner, with afci plug on a dedicated line, on a 20 amp breaker. Why does it nuisance trip, and not allow me to reset it, is it because of the 20 amp breaker? DRJ
It's definitely not related to the 20 Amp breaker. You do mean GFCI, right? The kind built into the end of the cord on the air conditioner, right? The GFCI is either detecting a ground fault (which means it's doing it's job and there is something wrong with the cord or the unit) or you have a bad GFCI. If the GFCI is in the wall receptacle, that could be a different story.
Jun 24, 2010 | Solar 15 Amp Murray Afci Circuit Breaker
My Whripool HE Front Load dryer keeps displaying PF and shutting off?? what does it mean??
this means a power failure.check you power cord and outlet and make sure that the cord is plugged in all the way. i would also suggest that you check your circuit breaker.also make sure the wiring terminal connections arre tight. i hope this helps good luck
Jan 22, 2010 | Whirlpool ET8CHEXSQ Dryer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My house stereo dose not turn on ive tryed the fuses and it still dont work what dose that nmean
means you most likely have a short it's nothing to bad jest go to your local hardware store you will find spare cords make sure you get a cord that can handle the amount of volts
Jun 07, 2009 | Farenheit TID-400 Car DVD Player
GE Electric Smooth Top Range Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
