Question about Rolatape Alvin 718R Temp. Int Dsgn Living-dining
Why do I have low flame on all settings
Seems that the regulator isn't allowing enough gas to get to the flame area. Sarts at low temp even though all outlets have a low blue flame. If I turn it down, the flame goes out.
I can not get my flame to come up to temp. When I turn one of the other burner on the first flame dies down to nothing. It is just not generating enough heat to cook. I did try different propane tanks and...
This is a typical symptom of a failing LP regulator. Replace the regulator and hose that attaches to the LP tank. When a regulator is failing, it allows enough gas through for the burners to light, but not enough to keep all the burners going at the same level.
Jul 03, 2011 | Jenn-Air Grilling
MY FLAME IS TO HIGH EVEN WHEN I SET IT ON LOW
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 08, 2010 | Weber Genesis Silver C Grill
Our complex has two Dacor BBQs. Both give off very low heat. It takes 15 mins to get the temp up to 300 and that's as high as it gets. The flame to me look low (weak). Many times the flame cannot make...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Dacor Grilling
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Low flame
Next time you use the grill turn the gas on slowly. For some unknown reason when turned on quickly the regulator reduces the gas flow.
Another problem with some gas fittings is an auto shutoff if detects the slightest leak. Sometimes the shutoff is not 100% and allows a small amount of gas causing the weak flame.
Apr 27, 2010 | Weber Genesis Silver B Grill
Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Sep 04, 2009 | Empire DV-35 Heater
Low gas flow - low heat
Hi Lyon,
Yeah, it's the regulator. Fortunately, they're cheap and easy to replace!
You can look on line for part number 80012. Or you can remove yours and take it to Home Depot or Lowe's in the outdoor cooking area and match up a replacement. <--- they're all the same... just make sure the compression fitting (the brass end) is the same size.
The only other thing I could recommend is this... Turn the LP bottle completely off. Then completely remove the big plastic knurled knob from the tank. Now replace the knob back onto the tank (all the way and make sure it's tight). Then S L O W L Y turn the gas back on. Now try your pit. If you get the same flame, it's the regulator. If you get full flame, you just reset the safety device inside the tank.
I'm betting regulator. Good luck and happy cookin'!
SG
Jun 03, 2009 | Weber Q Grill
Heat is about low or just a little higher on high setting
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
My weber Baby Q grill has a low flame.
Agree with rjmbridge. I called the Weber support people and was told that there is a built in safety feature on the regulator that will cause the flame to burn at a low setting if the gas within the extension tube to the large tank and regulator is not allowed enough time to equalize. They suggested turning on the gas from the tank very slowly, allow about 2 minutes with the temperature control knob turned off, then turn the temp knob on and light. This worked for me.
May 27, 2008 | Weber Baby Q Grill
Rolatape Alvin 718R Temp. Int Dsgn Living-dining Logo
Top Rolatape Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Rolatape Furniture Expert? Answer questions, earn points and help others
