Question about Hotpoint Aquarius WMA42 Front Load Washer
I cannot read the intructions on my Hotpoint aqaurius wf325
I have purchased my Hotpoint Aqaurius WF325 second hand Hand, but I cannot read the programming information (ie: F. Non Fast Coloured etc) it's disappeared and I don't know which program to use. I need a copy of the front of the washing machine visably showing the details so I can read which program I need. Can anyone help me please.
  • 41 Answers
Go online hotpoint will supply you with handbook probably download from their website hope this helps
Posted on May 11, 2014
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wf325 filter problem, Blocked maybe?
You are correct as to the location of the filter.
Remove rear panel, locate large black hose at right lower side.
Remove securing clip and hose, inside you will see the plastic filter, remove and clean filter, note location of plastic ball.
Refit filter and hose, and securely fasten hose back on.
When you remove hose, watch out for water, as there will be some in the hose.
water test before fitting panel back on.
Plz rate my solution
Thanks.
Posted on Jan 08, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wf325 filter problem, not accessable??
If you are certain that your washer has no filter at the front behind the lower removable panel, it is usually held on by 3 scews which you have to undo, or just held in place with plastic lugs, then you will have to remove the lower rear cover of washer. Locate large black hose at lower right of tub, remove clip and hose.
Remove and clean filter, refit filter and plastic ball if it has one, refit hose and clip securely, and water test for leaks.
Be careful when you remove hose as there will be water run out.
Please make sure you have it unplugged before you do all this.
Plz rate my solution, and feel free to leave any comments.
Thanks.
Posted on Jan 09, 2009
  • 20 Answers
SOURCE: my washer keeps reading either F04 or F05
Is your dryer gas or electric?
Posted on Jan 19, 2009
  • 100 Answers
SOURCE: hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Posted on Jan 28, 2009
The drum on WF325 hotpoint washing machine does not rotate
Sounds like your gearbox/transmission has went out. Usually cheaper to get a new washer than to replace. Sorry.
It is not the motor, if the water is draining - pump is attached to motor.
Hope this helps...
Jan 07, 2012 | Washing Machines
I want instruction manual for WD62 aqaurius washer dryer
Hi
I have one. I can scan it for you but not sure what to do with it then!
Jun 17, 2010 | Hotpoint WD62 Front Load Washer / Dryer
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
Can hotpoint aqaurius 900 WM61 operate from cold water supply only
Hi.
Yes it can.
You to purchase an adaptor called a "Y "piece for the washer..
B&Q sell them, they are easy enough to get hold of.
Fasten the straight end of the adaptor on to the cold inlet valve..
Then fasten the 2 inlet hoses to the other 2 connections, and the 2 hoses as normal to the washer,,
Then whatever prog you select, it will draw \in cold water.
All new washers are now cold fill only, so you will be right up to date..
This will solve your problem.
Dec 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF325 won't pump out water
Item stuck in pump,open back and take out,unless u r in nottingham i can do 4 u
Oct 06, 2009 | Washing Machines
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint dryer
two pipes on the back (white + grey about 8mm dia) dissconect and blow down them both. May be blocked.
Jan 24, 2008 | Dryers
Hotpoint Aquarius WMA42 Front Load Washer Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
