Question about Xante Ilumina Digital Color Press Printer
How do i get into service mode for a xante ilumina 502
4 Suggested Answers
  • 202 Answers
SOURCE: how to install xante ilumina drum units?
When you unpack the drum it has like a white nylon and three orange plastics. Remove the three plastics(tapes are holding the plastics) and at the end remove the white plastic it has an arrow. Do not touch the drum. Make sure not to much light hits the drum. You have four drums remember to sit correctly the drum and to its correct position.
Posted on Mar 16, 2010
SOURCE: Good day
Most of the times the color background is a drum issue. The bigger the temperature, the more you will see this effect. There is a setting in the printer's menu, it's call BG Setting. Print the configuration menu to find it.It reduces or increases the background toning. Try this.
Posted on Nov 02, 2013
SOURCE: problem
what kind of paper do you use? do you see this effect in light paper also? Most of the times the color background is a drum issue. The bigger the temperature, the more you will see this effect. There is a setting in the printer's menu, it's call BG Setting. Print the configuration menu to find it.It reduces or increases the background toning. Try this.
Magenta Stained product on a Xante Ilumina
i want to ask few question, are you using correct envelopes for this machine or can you use any type, is the weight of paper like is 20lbs
paper, or is it cheap 99 cents paper.
the port where the color ink is spout or ejector port is issue.
call the manufacture customer care center ask for technical services.
go online to the following sites for more help or informations.
www.ask.com/mfg.name/make/model/
/service/manuals/
/operational/manual/
/troubleshooting/guide/
/FAQ/
/customer/service/telephone#/
Oct 06, 2015 | Xante Ilumina 502 GS Digital Color Press...
How do i fix the little black piece that broke off of the fuser exit sensor on my Xante Ilumina?
Amanda,
The problem is related to the paper exit assy. Their is no problem with your fuser assy. Take a look at the exit document related to your problem. Usually that is cause when removing a paper jam, that switch flags break for pulling the paper in the back direction. You would have to replace the paper out exit swicth black actuator.
Oct 03, 2014 | Xante Ilumina® 502 Laser Printer
I have a xante 502 it has streaking on the top side of printing I printed each color and streaking is on each color with black the worst what part do I replace?
if you are familiar with ilumina menu search for the ID Test Pattern. Print test using 11 x 17 page.
On the copy you will see which of the drums need to replace, if the copy has vertical or horizontal lines on it the drum which ever color shows it has to be replace.
Jun 19, 2014 | Xante Ilumina® 502 Laser Printer
Yellow registration problems on xante 502
clean all the registration sensors on the imaging drums and at the fuser end (there are 3 under a shifting piece of white plastic on the left side after transfer belt is removed.
May 15, 2014 | Xante Ilumina Digital Color Press Printer
128:error fatal 02
Engine FAN Motor Error
02: Power FAN Error
is the applicable location of the fan connection normal?
If the condition does not change Replace Fan.
Mar 15, 2012 | Xante Ilumina® 502 Laser Printer
Good day I have a Xante Ilumina 502, when i print on 300gsm and up there is a magenta background. How do i solve this
Your settings are incorrect, adjust media type and media weight. This settings adjust the temperature of the fuser. If fuser to cold you will have ghosting and fuser to hot image will stick to fuser.
Mar 31, 2010 | Xante Ilumina® 502 Laser Printer
Glossy Paper descalibrate my Xante Ilumina
We found that the lighter the glossy paper, the worse the problem. I think the Ilumina is so hot that it literally melts the paper. We have great success using 100# gloss offset.The heavier, the better.
Oct 15, 2008 | Office Equipment & Supplies
79 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
