At the time of starting water going out without washing the cloth
  • 101 Answers
SOURCE: It does not agitate when its time to wash my clothes, but it spins when it dries
The drain pump is getting stuck, there may be something jamming it or the pump is defective needs to be replace.
Posted on May 12, 2008
  • 330 Answers
SOURCE: Washing machine wont circulate the clothes, the thing inside wont move
Check the belt, either loss or broke
Posted on Jul 03, 2008
  • 254 Answers
SOURCE: water problem
  1. Calypso washer
  2. FAQ's for washers
  3. Frigidaire, Westinghouse top load washers
  4. Frigidaire front load washers... ( some GE and Kenmore are made by Frigidaire )
  5. GE  newer style washers - after approx 1995
  6. GE  older style washers - pre approx 1995
  7. General Washer Information   - how does my agitator come off, filling problems and much more...a great place to start!
  8. How Washers Work
  9. Maytag Dependable care top load washers
  10. Maytag's SE1000 electronic stackable diagnostic chart
  11. Maytag's Neptune front load washer
  12. Maytag's Atlantis "how to take apart"   Which is very close to the Performa & Magic Chef
  13. Maytag Performa & Atlantis plastic tub washers....Norge, Magic Chef,American Admiral washers
  14. Noise tip for washers and dryers
  15. Speed Queen and Amana washers
  16. * Whirlpool, Inglis, Kenmore Direct Drive washers
  17. * Whirlpool, Inglis, Kenmore Belt drive washers
  18. Whirlpool, Duet front loading washing machine ( some of the Kenmore's as well )new25.gif
  19. Own a Kenmore? Department store brands can be a pain as it is difficult to figure out which manufacture has made your product. This link here should help to find out which manufacture has made your Kenmore Appliance.
  20. How old is my appliance help for some of today's major manufactures
  21. Cleaning and laundry tips
  22. Repair manuals can be ordered here: Appliance Repair manuals
  23. Washer timer knobs and how they come off
  24. Washing machine dancing across the floor? - Here's some tips on how to keep it in its place
Posted on Apr 01, 2009
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
57 varieties
  • 1653 Answers
SOURCE: why is the water not staying in the machine to wash the clothes
This usually indicates that the drain hose is too low for the required height for the machine. What you are experiening is a siphoning action. Check your user manual for the exact height and make sure that your drain hose is set to that height, or slightly higher, into the waste pipe.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Posted on Sep 27, 2012
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
Water going in 2 the machine after the load is finished and the clothes r taken out
bad water inlet valve or control board? foes it do it even after u unplug it? if so then its ur water inlet valve if it stops after unplugging it its ur control board
water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-5.jpg ALSO CHECK THE WATER PRESSURE SWITCH BELOW
May 27, 2015 | Tricity Bendix AW1000W Front Load Washer
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
No problem just want to know if one can put clothes soaking in bucket into the machine and go straight to spin to get excess water out without going thru the whole washing process. Cheerz!
Hi - yes theres a few options start it on the final rinse and set your water level to low or auto sense then spin speed (this will add more water to stabilesde the spin cycle)
Could go direct to spin as well but you will need to adjust the clothing proper prior to starting of the cycle..
Jul 10, 2011 | Fisher and Paykel GWL11 Top Load Washer
I am very unhappy with this machine and sorry I bought it! It uses so little water that sometimes when I take the clothes out after it is finished washing I can see dry spots on the clothes that never even...
How about putting the clothes in and pouring water over them with a jug before the washer starts its program ?.
It could also be that the water level switch is out of tolerance and needs replacing
Most machines have a pre-wash cycle as well
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
