Question about Grilling
I have a stainless Steel Ducane grill with an infrared rotisserie burner. The rotisserie burner will light and then go out. Change the butane bottle still does not work.
    Problem Solver:
  • 8 Answers
Blow the burner out with air from the front this should help.
Posted on Aug 05, 2009
  • papawof4girl Aug 05, 2009
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
None of my igniters on my 30400043 Ducane grill will light the burners. I've had a grease fire due to the burners rusting out and replaced the burners. The insulation on the wires to the igniters has...
As I tell customers, when they ask me, "How long will this grill last?" "That depends on well you take care of it with routine maintenance and cleaning."
The wiring for the electronic ignition and the spark ignitors are replaceable. The ignitor button or the "clicker" as you called is replaceable. But all you may to do, is change the battery inside the igniter button. To help you further, i have included a link to the Owner's Manual for your grill. It will have an exploded view of the parts, which should help you identify them by part number and order them from Ducane, if you like.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
A far as the infrared burners are concerned, they blow out easily if the wind is just blowing slightly. That's why they have a thermocouple on the burner, to turn the gas off to it, when it gets blown out. When preheating an infrared burner, the hood/lid of the grill should be closed.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Ducane 30400040 Stainless Steel Grill
When using rotissery should main burner also be on?
NO, the grill will overheat with the lid closed. Besides, you will probably have to remove the cooking grates under the rotisserie , because a disposable drip pan should be placed under whatever your cooking.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel grill. The Rotisserie will light, but the burners will not. I purchased the grill in 2005.I have taken the grill apart and the tubes are clear. There is NO spark going to them. I...
The ignitor wire to the burners my have come loose or has lost full contact. Trace the wiring from the Ignitor Button to the main burners. Note if it loose or has come completely off. Also, check inside the grill at each burner to see if the ingnitors are covered with grease. If that's the case, clean them with alcohol and either a rag or a cotton ball. If all this fails to solve your problem, change the battery in the Ignitor Button with a brand new Alkaline type battery.
Hope this helps solve your problem. Happy Grilling!
Feb 12, 2011 | Ducane 30400040 Stainless Steel Grill
I have a Dukane Stainless Gas Grill (Five Burners, a Rotisserie and Stove top). It worked fine for three years. Now, I am not able to light more than one burner (of the five). When I go to put the second...
It's possible you may need a new regulator, but usually this problem is due to opening the propane tank valve too fast, which can cause the built-in excess flow valve to check closed to only a trickle. Next time you use the grill, very slowly open the tank valve and see if that solves it. If not, replace the regulator. Douglas
Sep 21, 2010 | Ducane 30400040 Stainless Steel Grill
Side burner on my Ducane 30400040 LP gas grill has a tall yellow/orange flame. How do I adjust?
Try blowing the burner out with compressed air. They're not adjustable but can get clogged up and change the air to gas mix.
Apr 25, 2010 | Ducane 30400040 Stainless Steel Grill
My 30400040 is rusting to pieces and is only 3
the casing sould have a long warranty but the burners and the cook surfaces do not
you must keep them oiled with veggie oil after cleaning to prevent corrosion
i keep a pump bottle with oil for this reason
Jun 25, 2009 | Ducane 30400040 Stainless Steel Grill
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Grilling Logo
285 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
