Where i get the parts of 50 cycle air conditioner from trane company
    Problem Solver:
  • 19 Answers
Trane in Houston Texas they have a web sight
Posted on May 06, 2014
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
What voltage required for trane ac with model # bwc060d400h0
Should be 240volts. Trane in a "secret" company that don't like to share any of their info with the public. I tried to look up the model # (great job to you for including make & model!) and found nothing. But.... If you look at the tag on the unit or some of its components it should give you a voltage rating
May 29, 2015 | Heating & Cooling
How can get the parts part of 50 cycle air conditioners
50/60 cycle parts are close but to get the oem your going to have to find the manufacturer representative for the part you want. Google the brand name and model number it should come up.
May 06, 2014 | Heating & Cooling
Heat pump Trane XE1000 needs new condensor motor and run capacitor
you could replace it yourself remove old mtr & cap. info. you need should be on body of each if not check unit call supply stores or local company for parts
Mar 22, 2012 | Heating & Cooling
Trane xe 70 cycles through the gas release cycle but fails to ignite the burners, upon inspection it appears that the igniter isnt glowing
Either the circuit to the electronic ignitor is bad or the ignitor (electrode) itself has failed. Either are not difficult to replace, but you will need a circuit tester to troubleshoot which part(s) needs replacing.
Mar 27, 2011 | Heating & Cooling
Item Potential Relay Type Pro Pac
get solid state starting relay and 65Uf cap from any refrigeration parts shop or to test comp remove all wires and hot start it or email me your wireing plans and relay info p.hampton25@yahoo.com.au
Apr 23, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Trane AC Compressor fan cycling on and off.
it depends on the tempareture you have set that is why it was going on and off
Sep 09, 2009 | Heating & Cooling
Is it normal for my 4 ton Trane compressor to rapid-cycle (about 5 seconds) during the hottest part of the day?
it must be over heat compressor,try to decrease temp on thermostat,probably will work
Jul 05, 2009 | Heating & Cooling
Trane air handler cycling rapidly
Depending on the age of your Trane unit. The fan relay has a time delay. This is a solid state board on the relay. Most of the time they stick on or off. Check for loose wires. But start with relay.
Jun 03, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
