Question about Kenmore Dryers
Is there a fuse in dryer kenmore elite model # 592 895090
  • 146 Answers
SOURCE: kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Posted on Dec 22, 2007
rdial54
  • 14 Answers
SOURCE: model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Posted on Dec 23, 2007
SOURCE: Error message F44 in a Kenmore Elite Dryer. What
F-44 indicates a faulty blower motor controller. $169.00 from sears
or about $115.00 from an appliance parts store. Also note: the
service technicians repair guide is usually folded and tucked inside the top of the dryer console. It contains all the F codes and disassemble and reassemble and testing instructions. Part # for the service guide is (W10035270).
Posted on May 15, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
If you have questions, please let me know. I hope this helps you.
Posted on Sep 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Kenmore elite dryer 110.67032600
Have your thermal fuse and thermister checked if either is open which means blown the dryer will not function. go here and enter model number www.repairclinic.com
Mar 19, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
199 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
