Tricity Bendix auto washer dryer 1200 - there is power to the machine but when door closed no water comes through - can you help?
Why is there no water filling the drum
Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Apr 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Bendix washer-dryer door won't open
if you remove the panel in the front lower right hand coner of the washer you should be able to feel around in there for a plastic cord. pull the cord to manually unlock the door
Nov 24, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Brand new washer dryer leaking - Triciy WDR1241
Go back to dealer ,make sure it is plumed OK .close bye
Oct 08, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
