How can get the parts part of 50 cycle air conditioners
  • 44 Answers
50/60 cycle parts are close but to get the oem your going to have to find the manufacturer representative for the part you want. Google the brand name and model number it should come up.
Posted on May 08, 2014
Displays CH04 error
Hello
THis is a heatsink Temp sensor open circut error.Try cycling power on and off to unit.If this does not work you will need sevice as this part is part of the control board.
Sep 17, 2011 | LG LSC121PMA Split System Air Conditioner
My air conditioner compressor is cycling on and off. The car is a 2007 Pontiac G6. Only blowing warm air.
Usually if its "fast cycling" its low on freon which means you probably have a leak also. After adding the freon to the proper level the fast cycling should stop and you should have cold air in the low 50 degree range coming rom the vents. You can buy the cans of freon with the pressure gauges built into them so you can gauge how much to put in. It's based on outside air temperature. Follow the instructions carefully and you shouldn't have any issues.
Jun 04, 2011 | Pontiac G6 Cars & Trucks
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
AC keeps cycling on and off. Have to set
If it runs o.k. at 50, I'd say check thermostat.
Aug 16, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner wont cool below 75 degrees
Hi, Does thermostat on a/c goes lower than 75? put hands close to air coming from a/c is it cold, like 50, if it's cold like 50, maybe you a/c are to small for space, check a/c b.t.u's ( british thermal units) how many b.t.u's is your a/c , there are a chart, for size of room and how many b.t.u's you'll need to cool space (room), or possible if air coming from a/c are 75, your compressor could be short cycling, it hard to tell when fans are working, listen carefully to hear if compressor makes clicking sound, place thermometer close to a/c vent and let me know temp, maybe there's freon leak. let me know temp of air coming out from a/c, then i could tell you exactly what's problem. good luck.
Aug 11, 2009 | Sunpentown WA-1230E Air Conditioner
Air conditioner will not cycle off when set below 83-84 degrees in the hot part of the day.
The thermometer or thermostat may be faulty and will have to be tested and diagnosed. Check for any broken wires or frosted up parts.
Jun 30, 2009 | Heating & Cooling
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Fujitsu Reverse Cycle Air conditioner problem
WILL NEED MODEL AND SERIAL# WHERE ARE YOU LOCATED?
Dec 12, 2007 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
