Question about Dryers
Dryer no power
Can hear timer but dryer is not operating so I think it is not getting any power?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Could be door switch, or belt switch , or thermal fuse
Posted on Jun 29, 2014
Dryer won't start? It has power and I hear the timer clicking.
Sounds like a bad door switch ( the little button the door closes against). If that switch is bad, the dryer thinks the door is open even though the door is closed. Dryer will not start. thats the easiest place to start.
May 11, 2015 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Timer no longer working - after 4 years of more or less flawless operation, we came home from a long night out last night to hear the dryer still running when we got home (4+ hours after starting). I...
don't think it is your timer, sounds like a venting issue, but here is a website that will show how to test and they sell parts, Good Luck Tim
Feb 27, 2011 | GE DPSR610GGWT Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
I have a whirlpool dryer, model number lgt6634dq0. The timmer does not stop after the drying cycle has ended. My guest it might be the timer. After the dryer has finished it's cycle I can hear the timer...
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
Dec 03, 2009 | Whirlpool Dryers
WILL NOT COME ON .IT HAS LINE POWER FOR SUPPLY BUT SWITCH DO NOT START THE DRYER .whirlpool roper dryer
check the door switch. if the machine think the door is open, it will not start.
just locate the switch that the door would normally hit when you close it. operate it a few times with your finger. you should feel or hear a click when the switch closes. if you don't, the switch will need replaced.
other than that your timer is suspect. it is much more expensive to replace. good luck
Nov 06, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Clothes dryer troubleshooting
my kenmore dryer keeps on drying after the alotted time has expired, i think the timer is the problem. how can i verify and fix this??
teddy
Oct 27, 2007 | Dryers
Dryers Logo
22 people viewed this question
Top Dryers Experts
