Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
    Master:
    Sergeant:
  • 388 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
Posted on Aug 15, 2016
5 Suggested Answers
james3751
  • 614 Answers
SOURCE: I have LG 1.5 Ton split ac-2 year old never
The only service you can do is change filters clean the dran and wash off the outside coils. Sorry Rsuty
Posted on Jun 14, 2009
BIKER T
  • 909 Answers
SOURCE: best split ac 1.5 ton
I think you just have a faulty unit. Most of the mid wall split units have similar components and there are only cosmetic differences. Lg is strangely enough a good aircon. Personally i like Samsung .(Spares are easily available). You should concider who the best after sales service supplier is and go that way. (As stated, most units are similar in my oppinion.)
Posted on Sep 21, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: My 1.5 ton,LG split AC shuts off rather
Hello
First the foam insulation is not just for looks,you will have some loss of cooling on the unit,the larger cooper line needs to be insulated,the small one does not.The large line is the suction line,the small one the liquid line.
Voltage,168 is low,sounds like a 208 volt unit or 220 volt.running at 168 or 198 ac volts is going to raise the amperage causing the compressor to run hot and work harder and soon burn up,And cause it to trip the breaker or shut itsself down on high heat.Your going to need to get that voltage fixed.I dont know why it needs a stabilizer if the unit was sized correctly it shouldnt need one.
Hope this helps.
Posted on Apr 14, 2010
SOURCE: split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Posted on May 24, 2012
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Best split ac 1.5 ton
Sep 21, 2009 | LG Heating & Cooling
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
32 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
