Question about Lomanco PCVI POWER CRAWL SPACE VENT Fan
Humidity build up in crawl space
Rectrangular 1680 square foot crawl space which is 5 feet high.I have two vents which have 110 cfi fans in each vent.I am thinking of getting two fans 220 cfi which will go into another vent locatied on the side of the crawl space. I dont know if that is going to be enough drawing power to do any good. One more thing is that the two fans (220 cfi)which are on a single humidstat.
  • 1 more comment
  • thomas_sm520 Jun 22, 2009
    The floor of the crawl space is stones with a vapor barrier sheet on the top.,There are no heating or cooling systems in the space. Being that i live in tennesse we have a humidity problem.I dont think my two little fans 110 cfi is enough,they are located at the far end of the rectangulaf shaped crawl space.
    I am impressed with your follow through on my problem.It seems to me that the four fans would encompass the area in question.I again thank you for more feedback and i will keep you in mind if any further problems occur.
  • boss dad May 11, 2010
    what kind of floor is in the crawl space --- also, what kind of area are you in and what is the ground like around the crawlspace --- any heating cooling equiptment in the crawlspace --- we need to first determine the source of the humidity before considering types of ventilatio or circulation
  • 67 Answers
You have to get a constant flow of air through there to prevent that build-up. By the time the humidistat calls for the fans to come on you have already lost the game. you need plenty of venting on all four sides to kep the air moving and preventing buildup of humid air. the 2 fans of 220 each are sufficient, put place them apart so you draw air in from all the vents (at least 4 intake vents ) and provide for movement of the full crawlspace area air ---- that is the key for your sitation. Make sure you have enough vapor barrier over a good base of stone----4 mil plastic or heavier and about 3 inches of stone. All in all, check on what it would cost to have concrete poured, especially if you get a lot of cold air conditioned air seeping down from up above and causing condensation ptoblems.
Posted on Jun 22, 2009
  • 130 Answers
Yes we had that problem a couple of times a couple of years ago and installing another unit cut it less than half.
Turn 675 squared feet into room dimentions
You can devide it up how you want. 675 squar feet is like having 675 one foot by one foot squars so a room that is 10 foot in one direction and 10 foot in another is 100 square feet so 6 of those would be 600 square feet and say a room that was 7.5 foot by 10 foot would be 75 foot
Feb 14, 2015 | Office Equipment & Supplies
What is 9600 cubic ft converted to square ft?
Cubic foot is a unit of volume. Square foot is a unit of area. There is no direct conversion between them.
A 9600 cubic foot room with a ten-foot high ceiling is 960 square feet. If the roof is eight feet high, the area is 1200 square feet. If the roof is 12 feet high, the area is 800 square feet.
Jul 02, 2014 | Office Equipment & Supplies
Cubic feet calculator
Cubic foot is a unit of volume. Square inch is a unit of area. There is no direct conversion between them.
An area of 144 square inches and a foot high would be one cubic foot. So would an area of one square inch and 144 feet high.
Jan 15, 2014 | Office Equipment & Supplies
Need for a home dehumidifier for a 120 square meters space
normall you will need one pint of water for each 1,000 cubic feed of space in your . . example. 2,000 square foot with 8 foot ceiling would contain some 16,000 cubic feet. = 16 pint per day capcity to dehumidify the area.
God bless you
Oct 29, 2013 | DeLonghi DH100P Dehumidifier
Air is blowing cold but wont keep up temp
If the system is actually doing everything it can, which I do occasionally run into, then it's time to start looking at other factors like the heat loads. Number one problem I run into is either attic insulation or attic ventilation. One thing that really sticks out in your post though is the square footage and tonnage. Now, to be honest, what the square footage is from the home owner to actual living space always varies. Home owners always get the square footage like a realtor, but includes the garage and other unconditioned rooms. What your looking for is the square footage of only the rooms that have a vent. It is 400cfm per ton, 1 cfm per square foot. So if you have a 2.5 ton system, it is capable of doing 1000 square feet of living space. You said 1500 square feet, which would need a 3.5 to 4 ton system. Hope this helps and gets you to cooler days!
Jul 01, 2012 | Ruud UBHC Air Conditioner
What is the best humidity setting for a four foot high crawl space?
Depends on the cubic footage (length x width x height = cubic footage) and how damp it is. If you're not going to have to dump the collection tank (a drain hose is connected to the unit to run water out of the craw space and away from the house), I would run it on high for 24 hours and then lower it to medium for several days. After that, you should have a pretty good indication what it takes to keep the craw space dry. At least, until the next heavy, continuous rain storm.
If this is an on going problem, I'm not sure that a humidifier is the total answer. You need to look at the causes for this moisture (i.e) Are the downspouts carrying the water away from the house? Are the gutters and downspouts clogged with debris, causing the gutters to overflow? Does the earth around the foundation need to be regraded, so that water runs away from the foundation? Has the moisture barrier on the outside, underground around the foundation failed? Would installing an automatic sump pump in the crawl space be more efficient?
So, in addition to the dehumidifier, you need to look at the big picture and eliminate the cause(s).
Hope this helps to solve your problems.
Mar 09, 2011 | LG LHD45EL Dehumidifier
What is the lowest temperature I can maintain with this heater ? That is, I plan to use it in crawl space where water pump and pressure tank and copper pipes and water heater are located and in winter...
YOu are asking a question that cannot be properly answered without knowing more of the situation. If this crawl space is subject to large air drafts and there are air vents that allow openess to this area, then you cannot be sure of the results. Since it will be winter, the humidity build-up is not so much a factor and you should take steps to isolate this area from air movement. Then you can apply heat. You may want to make a temporary plywood barrier around this area so your heat stays confined, thereby using the minimal heat needed to keep the temp you want. The heater will most likely handle the job; you should get a thermometer and keep the space at 40 degrees farenheit or slightly higher. When the warm weather arrives, remember to open the air venting again.
Oct 11, 2009 | Patton Electric Patton PUH680-U Electric...
Tankless water heater venting
You get a wall vent for that heater. This room is not inclose is it?If not then wall vent would work just find.
Mar 14, 2009 | Rheem RTG74DVN Direct Vent Natural Gas...
Lomanco PCVI POWER CRAWL SPACE VENT Fan Logo
204 people viewed this question
Top Lomanco Dryers Experts
Marvin
Marvin
Are you a Lomanco Dryer Expert? Answer questions, earn points and help others
