Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
How do i regulate temperatures?Where are the controls?
I have inherited this unit and have no instructions.There seems to be one control in the fridge compartment fro 1-5 and no control in the freezer compartment.
fanny
  • 146 Answers
SOURCE: Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Posted on Nov 03, 2007
SOURCE: Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Posted on Mar 19, 2008
  • 1462 Answers
SOURCE: Bosch KGU44120 frost free fridge
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Posted on Jul 05, 2008
SOURCE: Bosch Classixx Frost Free KGU34640GB/06
the freezer is not defrosting at all .How to defrost it ?
Posted on Aug 01, 2008
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
Food on top shelf is freezing
Not sure what model you have so I need to guess that it only has a thermostat control that regulates temperature? Can you post the Model Number? If your model only uses the temperature control to regulate temperatures then I suspect that the temperature control is at fault and needs replaced. Spare parts HERE Can you locate your model number? Click HERE I am here should you need me, Thanks John TrippAppliance 911
Contact Me Here
Mar 12, 2014 | Hotpoint-Ariston Refrigerators
Ignis fridge isn't cold enough, and seems unable to maintain a constant temperature. I bought a fridge thermometer to get some accurate data: fridge is typically between 9 - 15 degress c. Generally, a good...
the compressor is acting weird because the fridge might need regasing if the tempreture
uness the fridge controls for the tempreture nside the fridge are buggered and the thermostat
Jul 05, 2008 | Refrigerators
Tip
Hi Heatman101, I have the WHIRLPOOL GS6SHEXMS00 and seems to not to regulate the...
There are many people that come to Fixya.com with questions about a problem they are having. However, in their frustration, they forget that to answer the question properly, certain important information is needed. Questions like "no heat" or "it does not work" have little value...
For a competent expert to be able to answer your problem, you will need to give a specific make and model of your unit.
Also include as much as possible about what you have already tried to do to resolve the problem along with exactly what is not working or what the unit is not doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the first time, without having to guess so much as to what is actually happening.
Thank you!
heatman101
on Jan 20, 2011 | Refrigerators
Temperature controls
The control on the back wall controls the freezer part of the unit,,the one on topof unit and the closest to you, controls the refrigerator( bottom ) part of the refrig. Temp.
Jun 07, 2012 | Frigidaire Refrigerators
Fridge is freezing the contents solid even when thermostat set at very minimum.
Possible that the thermostat is faulty and is not regulating the temperature.
Check to see if there is any wire break into the freezer unit of the sensor,check the control, if not change the sensor unit.
Sep 18, 2010 | Refrigerators
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Refrigerator side is not cooling enough. Temperature is only in low 50's. Freezer side seems to be okay.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Dec 28, 2009 | Refrigerators
The freezer on my Liebherr fridge keeps filling too much with ice. The ice grows around the door and seal which makes it impossible to close properly. I inherited the f/freezer so I don't have the...
This sounds like moisture in being sucked in past the door seals. Remember, cold-- sucks temperature, (like a vacuum) and HEAT--- pumps away temperatures..So the warmer temp. are always being drawn in.. Thus, bad door seals, and need to be replaced --- cleanned---or repaired, but for now turn your thermostat or temperature up or the control knob back lower, (like from 7--to 5--ect. ect 4-to 2..)!
Sep 06, 2008 | Heating & Cooling
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
113 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
