Question about Kenmore 24032\24036 Top Load Washer
Remove cabinet kenmore 26882503
How do I remove the cabinet?
  • 122 Answers
Use a putty knife and slide under each corner to compress clips. The console should hinge backwards. Use a flathead to remove 2 clamps holding cabinet to base and disconnect lid switch. Pull on the cabinet and it will tilt towards you.
Posted on May 15, 2014
Remove cabinet on kenmore 11022972101
F.Y.I., the Kenmore product line is made for Sears by leading appliance manufacturers and branded with the Kenmore name. Sears does not manufacture any products themselves.
Whirlpool is the manufacturer for this particular model of Kenmore since the prefix number before the period (or dot) in the full model number is, 110.
Kenmore: http://www.searspartsdirect.com/partsdirect
service/repair manuals: http://www.appliancerepair.net/washing-machines-forward.html
Best regards
Mar 16, 2014 | Washing Machines
HOW DOES THE CABINET GO BACK ON A SEARS KENMORE 110.20712990
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020712990/0582/0153200?pathTaken=
Then see the following for how to remove and replace the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5cac791c099cfeceeefa8f469d527d82
Basically, the cabinet sits in slots in the base unit of the washer. Simply align the tabs on the cabinet with the slots and tilt the cabinet back.
Check to make sure that the back panel fits inside the cabinet.
Dec 04, 2010 | Kenmore Washing Machines
How to remove top of kenmore oasis washer to replace lid lock mechanism
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
How to replace kenmore elite washer model 110 16962503 lid switch
Let me offer you a generic solution for most of the Kenmore washers :-
There are 2 screws that secure the console to the cabinet top. The are located in the front or rear corners, and on a Kenmore, may be hidden behind the end caps. Remove the screws, and tilt the cabinet backwards. Remove the 2 gold clips, and disconnect the wiring harness. Tilt the cabinet forward, and off of the base. The lid switch can now be accessed from inside the cabinet (I sit inside).
Hope i helped you.
Thanks.
Aug 14, 2009 | Kenmore Washing Machines
Need to disassemble a kenmore elite oasis dryer
5
6
7
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Kenmore oasis toploader he l hinge and switch removal
5
6
7
Jun 06, 2009 | Kenmore 24902 Top Load Washer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I need to remove the back panel on my top load kenmore washer
5
6
7
Jan 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer
On the top load models, you need to remove the washer's 3-sided cabinet and then the pump is secured by two clips to the motor.
To remove the cabinet, open the control panel up, then find the two retainer straps that hold the cabinet in place. Pop them out with a screwdriver and pull the cabinet back and up. The pump is in he center by the floor, you can't miss it...
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Removing cabinet of kenmore elite washing machine
It would help if I had your model number, but I'm assuming you have a Kenmore top loader that has the fill hoses attached under the left rear of the washer casing. With the brass clips removed, you should be able to move the cabinet off the frame slightly to give you enough room to reach your hand under the wash tub rim and disconnect the hoses. You may need a set of pliers to remove the hose clamps. I hope this helps you.
If you are having difficulty, please post back and let me know.
Was there a reason why you were removing the cabinet? Do you need further assistance?
May 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
