Question about Beko Washing Machines
How do i get the beko xl9 to start working again, has flashing start symbol in the spin mode after trying to cancel the programme?
Have tried pressing start button but nothing happens and switched off by mains for quite a while.
  • 6 Answers
SOURCE: beko WMA 1715s - won't respond
door lock switch could be your problem..
Posted on Aug 30, 2008
SOURCE: I can hear the water
Not an answer to your problem but i am having the same problem with me 20 month old beko machine - a different machine to yours. I have had an engineer out twice already paid for by myself to rectify the problem and now it has happended a third time. The engineer seems to think it is poor quality wire used. Good luck let me know how you get on.
Posted on Oct 05, 2010
  • 6277 Answers
SOURCE: I turned my machine on
Could have water still in it from the last wash/rinse/spin so try this, please, but sorry, no promises!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 15, 2011
  • 6277 Answers
SOURCE: beko wm 5140 washing machine is starting its cycle
(no promises but it's worth carrying this out anyway!)
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
Posted on Aug 10, 2011
KevinWhite
  • 1902 Answers
SOURCE: beko wme8227w will not either start or cancel a
Hello & Welcome to FixYa
If the drain filter pump assembly located inside the bottom front panel is clean then the problem is with the door lock assembly that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Aug 23, 2011
I can hear the water going into the machine but after after a short while the machine stops, the start pause button and the wash button flash and the machine stops. I have held down the start pause button...
Sep 29, 2010 | Washing Machines
I have the test displayed and it dosent matter
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and test appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Feb 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Indesit1200 front loader not filling and flashing error code deno can anyone help
hi try these
To Activate
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
d OFF appears.
To Activate
To Deactivate
To Activate
To Deactivate
Aug 22, 2008 | Indesit Washing Machines
Hotpoint wf865
press on off button till test comes up then press on off and start cancel button together for a few seconds
Jun 26, 2008 | Hotpoint Ultima WF865 Front Load Washer
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Leave power on.
Apr 26, 2008 | Washing Machines
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
