Question about TruTech PVS31170S1W 17 in. LCD Television
Can I just plug the unit in and the tv and or dvd player will work?
    Genius:
  • 1,114 Answers
Yes it should work. You just need to hook it up to a video/audio source. and the DVD player should work- yes.
Posted on May 06, 2014
    Top Expert:
  • TruTech Master
  • 74,251 Answers
After switching its power ON, you can select its input to TV/DVD to watch videos. Gopakumar Gopalan Google
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like Ebay.com or Amazon.com buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
My little colby dvd player wont open or close and it wont turn off. if it would open, i would try to reset the remote..yes, i have plugged and unplugged and have it plugged directly into tv???
I assume you've tried plugging into a wall socket instead of TV?
Probably won't work, but push and hold power button on unit 10 seconds then release, for that matter try all buttons. Not uncommon problem, usually you have to UNPLUG unit, disassemble to remove DVD and discard unit if cheap enough.
Sep 26, 2009 | Televison & Video
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Aug 05, 2009 | Panasonic Televison & Video
Connected DVD Player to TV using HDMI cable doesn't work
Have you changed the input of your TV unit to AV1, AV2 or component...or what ever? If so and yet the problem prevails, then try to Plug the AV cable to the input of your Cable Box, if it has so.
If i was helpful, kindly do Rate!
Jul 21, 2009 | Toshiba XD-E500 DVD Player
Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Apr 07, 2009 | Televison & Video
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
TruTech PVS31170S1W 17 in. LCD Television Logo
41 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
